Help Needed In Selecting Dialogic Board
I am using a D/4PCI board for my IVR application . now i have to add conferencing feature in my application so that a user dials on a port application answers the call ask user choice for conference and then using another free port make an outbound call and connect the voice path of caller and callee. Plz suggest a board which support Prompt playback, recording and conferencing ?
thanx in advance ...
ashish
I read the specification of this board and its written no where that it supports conferencing.
If the board has the "CT Bus" or "SCbus" then you will be able to connect two calls together on the board.
This can be done using the "Dial and Conference" option of the "Call Transfer" module.
Alternatively you can use the Bridge_Connect and Bridge_Disconnect COM functions.
Please see the VoiceGuide Help file for more information on both of the above.
Online copy of relevant page is at:
http://www.voiceguide.com/vghelp/html/modXfer.htm
