kbamonte Report post Posted 04/20/2004 10:45 PM I am trying to get my script to print thru the print option on the "File Menu" in script designer. It sits for an extremely long time and then times out. (not responding error) The printer queue says spooling but nothing ever comes out. There is also literally absolutely nothing in the help section about printing out scripts. My questions are : 1) Is this function going to do what I'm hoping (print out the script in a graphical format as it is displayed on the screen) ? 2) What could be the problem with it timing out and never completing the print job ? (the script only has 25 modules or so) I am using win 2000 server with a hp deskjet 1120c printer Thanks in advance Kevin Share this post Link to post
SupportTeam Report post Posted 04/20/2004 11:15 PM Right now the print function will only print the part of the script which is visible on the screeen - not the entire script. Share this post Link to post
kbamonte Report post Posted 12/29/2005 09:22 PM Hi can you tell me if the print option of the Script Designer has ever been updated ? What is the latest version ? Thank you, Kevin A. Bamonte Share this post Link to post
SupportTeam Report post Posted 12/29/2005 09:55 PM No, it's not possible to printout what you see in the script designer at this stage. Share this post Link to post
ktruk Report post Posted 01/17/2006 10:54 AM The current screen print-out is a bit woeful, it misses the lines connecting the boxes (for me at any rate), which defeats the object of a print-out a little, so what I do is do a screen capture (prtsc or alt-prtsc) and print it out via some graphics software (eg: paint-shop-pro). Works a treat, plus you can annotate bits and paste several screens together if needed. Share this post Link to post
