​​​​​​​ SIP calls and DTMF issues
Recently I have DTMF issue with NEC SV9500. I did have ticket with Dialogic and Dialogic support replied.
The first comment from looking the below is that the ReINVITE is sent directly after the ACK received and causing an issue as well for processing in that case. Please see following technote where application needs change to handle the 491 pending situation.
PowerMedia HMP rejects a re-INVITE with 491 Request Pending (dialogic.com)
This call the DTMF couldn’t send from 10.92.8.13 to 10.92.38.27.
DTMF.zip
Can you please post VoiceGuide's ktTel trace that include in it the time from 11/30/2023 13:50 till 11/30/2023 14:05.
Also please post the latest ktTel trace that captures the VoiceGuide service start/restart on that system.
We can then confirm current configuration and behavior on this system and advise.
Please .ZIP up all trace files before posting.
Can you also please post VoiceGuide's vgEngine trace from Nov 29th that includes the VoiceGuide service restart.
Please post the other vgEngine trace from Nov 29th. The trace posted above does not include the VoiceGuide service startup, it only includes the shutdown.
A new vgEngine trace file is created at time of VoiceGuide service startup.
We have emailed a download link to a version of VoiceGuide that now implements the "491 request pending" fix.
In the attached DTMF_Issue_12062023.zip the ktTel trace is from 5th December (14:47 till 23:15) and the RTFLOG trace is from 6th December (00:42 till 00:57)
Please post the ktTel trace from 6th December. We can then correlate that VoiceGuide ktTel trace with the posted RTFlog.
That highlighted "3rd INVITE" does not contain any SDP information. So there is nothing in that 3rd INVITE that indicates how DTMFs will be sent on this call, so nothing that can be 'confirmed as accepted' with respect to that either in the returned OK.
The first INVITE does not contain any SDP either:
The second INVITE contains an SDP, but that SDP does not include any advice on how DTMFs are sent:
In cases where DTMF sending mode is not advised by the calling party it is assumed that the calling party will be sending DTMF's in-band. The "OK" reply from VoiceGuide to the 1st INVITE reflects that. (See screenshot below)
You could try asking the PBX administrator if it is their intention to not send any details on how DTMFs are delivered, and how are they actually sending the DTMFs (if at all) on calls such as these - where no DTMF sending method is explicitly advised by PBX during call setup.
The 1st INVOTE doesn't contain any SDP information, but 200 OK (5465) was different with the 3rd INVITE 200 OK (5492).
Why 3rd INVITE 200 OK "Media Description" doesn't have Media Format: DynamicRTP-Type-101?
THIRD INVITE's OK response:
FIRST INVITE's OK response:
Edited by SupportTeam
added headings to screenshots
The ACK (5469) sent in response to first INVITEs(5464)  OK(5465) contained an SDP that set 96 for the telephone-event:
                    Media Attribute (a): rtpmap:96 telephone-event/8000
                    Media Attribute (a): fmtp:96 0-11
so after VoiceGuide/HMP sent "101 telephone-event" in the OK(5465), the PBX responded with a "96 telephone-event".
I guess that means that even though PBX was advised that HMP is setting to use "101 telephone-event" , the PBX decided that it will be sending DTMFs using "96 telephone-event" approach.
So if you need for the OK that the sent in response to the 3rd INVITE to also contain a "telephone-event" media attribute, then should we now send "96 telephone-event" or the "101 telephone-event"  value?
Note that sending the "101 telephone-event" again might mean going against the PBX's just previously provided "telephone-event" setting...
Did the Administrator of this PBX advise what they need to see from HMP/VoiceGuide and when? Do they really need for the remote end to echo back to the PBX the value for the "telephone-event" that PBX has advised that it will be using on its connection?
Did the Administrator of this PBX specifically advise that they need a  "telephone-event" in that 3rd INVITE response? And if yes then what is the value they wopuld need? The one advised by PBX in its ACK, or having HMP send its original default setting (101) be OK and PBX will adjust the way it sends it's DTMFs accordingly?
What about the 2nd INVITE response? Does the PBX require us to include a "telephone-event" attribute line in that OK response as well?
Did the PBX Administrator specifically advise that it is lack of their PBX not seeing its "telephone-event" selection echoed back to it on the 3rd INVITE that is causing their PBX to somehow not send DTMFs?
FIRST INVITE (NO SDP)
5464 ---->
        Session Initiation Protocol (INVITE)
            Request-Line: INVITE sip:22702@10.92.38.27:5060 SIP/2.0
            Message Header
                Via: SIP/2.0/UDP 10.92.39.22:5060;branch=z9hG4bK1210454877
                From: "GEN INFO " <sip:23484@10.92.39.22>;tag=4b223407
                To: <sip:22702@10.92.39.22:5060>
                Call-ID: 117b5091@10.92.39.22
                [Generated Call-ID: 117b5091@10.92.39.22]
                CSeq: 1 INVITE
                Contact: <sip:23484@10.92.39.22>
                Max-Forwards: 70
                User-Agent: Enterprise IP-PBX (InSIPH)
                Allow: INVITE, ACK, REGISTER, BYE, OPTIONS, INFO, CANCEL, REFER, NOTIFY, SUBSCRIBE, PRACK, UPDATE
                Date: Thu, 07 Dec 2023 01:56:14 GMT
                Supported: timer
                Session-Expires: 180;refresher=uac
                P-Asserted-Identity: "GEN INFO " <sip:23484@10.92.39.22>
                Content-Length: 0
5465 <-----
        Session Initiation Protocol (200)
            Status-Line: SIP/2.0 200 OK
            Message Header
                From: "GEN INFO "<sip:23484@10.92.39.22>;tag=4b223407
                To: <sip:22702@10.92.39.22:5060>;tag=1e868f7d-787794c2-138f57-10483c08-0-13c4-764
                CSeq: 1 INVITE
                Supported: replaces
                User-Agent: MST/IVR
                Contact: <sip:22702@10.92.38.27:5060>
                Allow: INVITE, CANCEL, ACK, BYE, OPTIONS, INFO, REFER, NOTIFY
                Content-Type: application/sdp
                Content-Length: 223
            Message Body
                Session Description Protocol
                    Session Description Protocol Version (v): 0
                    Owner/Creator, Session Id (o): Dialogic_SIP_CCLIB 273387488 273387489 IN IP4 10.92.38.27
                    Session Name (s): Dialogic_SIP_CCLIB
                    Session Information (i): session information
                    Connection Information (c): IN IP4 10.92.38.27
                    Time Description, active time (t): 0 0
                    Media Description, name and address (m): audio 49154 RTP/AVP 0 8 101
                    Media Attribute (a): rtpmap:101 telephone-event/8000
                    Media Attribute (a): fmtp:101 0-15
                    [Generated Call-ID: 330d522c@10.92.39.22]
5469 ----->
        Session Initiation Protocol (ACK)
            Request-Line: ACK sip:22702@10.92.38.27:5060 SIP/2.0
            Message Header
                Via: SIP/2.0/UDP 10.92.39.22:5060;branch=z9hG4bK1893664471
                CSeq: 1 ACK
                Max-Forwards: 70
                Content-Length:   194
            Message Body
                    Owner/Creator, Session Id (o): 23484 0 1 IN IP4 10.92.39.22
                    Session Name (s): Std-SIP Call
                    Connection Information (c): IN IP4 10.92.39.22
                    Media Description, name and address (m): audio 60304 RTP/AVP 0 96
                    Media Attribute (a): ptime:20
                    Media Attribute (a): rtpmap:0 PCMU/8000
SECOND INVITE
5470 ----->
            Message Header
                Via: SIP/2.0/UDP 10.92.39.22:5060;branch=z9hG4bK1031855743
                CSeq: 2 INVITE
                Max-Forwards: 70
                Supported: timer
                P-Asserted-Identity: "WIRELESS CALLER" <sip:12409973549@10.92.39.22>
                Content-Length:   153
            Message Body
                    Owner/Creator, Session Id (o): 23484 0 2 IN IP4 10.92.39.22
                    Session Attribute (a): inactive
5471 <-----
        Session Initiation Protocol (100)
            Status-Line: SIP/2.0 100 Trying
            Message Header
                CSeq: 2 INVITE
                Supported: replaces
                User-Agent: MST/IVR
                Content-Length: 0
5478 <-----
            Message Header
                CSeq: 2 INVITE
                Supported: replaces
                User-Agent: MST/IVR
                Content-Length: 188
            Message Body
                    Owner/Creator, Session Id (o): Dialogic_SIP_CCLIB 273387488 273387490 IN IP4 10.92.38.27
                    Media Attribute (a): sendrecv
5479 ----->
            Message Header
                Via: SIP/2.0/UDP 10.92.39.22:5060;branch=z9hG4bK0028047973
                CSeq: 2 ACK
                Max-Forwards: 70
                Content-Length: 0
THIRD INVITE (NO SDP)
5489 ----->
            Message Header
                Via: SIP/2.0/UDP 10.92.39.22:5060;branch=z9hG4bK0020117955
                CSeq: 3 INVITE
                Max-Forwards: 70
                Supported: timer
                Content-Length: 0
5490 <-----
            Message Header
                CSeq: 3 INVITE
                Supported: replaces
                User-Agent: MST/IVR
                Content-Length: 0
5492 <-----
            Message Header
                CSeq: 3 INVITE
                Supported: replaces
                User-Agent: MST/IVR
                Content-Length: 144
            Message Body
5495----->
            Message Header
                Via: SIP/2.0/UDP 10.92.39.22:5060;branch=z9hG4bK2010659656
                CSeq: 3 ACK
                Max-Forwards: 70
                Content-Length:   140
            Message Body
                    Owner/Creator, Session Id (o): 23484 0 3 IN IP4 10.92.39.22
                    Connection Information (c): IN IP4 10.92.8.10
                    Media Description, name and address (m): audio 51000 RTP/AVP 0
Dialogic did also point out that PBX send payload type 96 for rfc2833 in their ACK after we send 101 from HMP side. We did ask NEC support engineer to fix PBX side.
NEC is checking on their side.
How about Dialogic comment about "pass a parmblk with the IP_CAPABILITY that has the expected rfc28933 payload"
Can you please test Re-INVITE handling with this version:
[removed]
and then post the traces as before (vgEngine, ktTel and WireShark)
We can then see how this version handled this case and see if further changes are needed.
To change to a different version of VoiceGuide:
  1. Stop VoiceGuide Service. VoiceGuide can be stopped by clicking on the VoiceGuide Service Monitor in the Windows's Icon Tray on bottom right of the taskbar and selecting "Stop".
  2. Exit all VoiceGuide programs. This  includes the Service Monitor applet in the Icon Tray area in bottom right of the screen,  as well as the Script Designer, Line Status Monitor, etc.
  3. Do NOT uninstall the previous VoiceGuide installation.
  4. Stop the Dialogic service using the Dialogic Configuration Manager (DCM), or Windows' Services Applet.
  5. Run the VoiceGuide install and install into same directory as existing installation.
  6. Start VoiceGuide service.
Note: Running a VoiceGuide install over the top of an existing install will NOT overwrite existing configuration or license files (Config.xml, ConfigLine.xml, VG.INI, etc) and will not remove any of users script or sound files, and will not remove any log files etc.
newer version supplied to customer
An email has been sent to this customer detailing next steps that need to be made on both the Dialogic side and the NEC side.
