Internet Portal Sample
When I run the Internet Portal Sample script, I get an error during the say numbers module:
Windows Script Host
Script: D:\Program Files\VoiceGuide\data\vbs_5_SayNumber.vbs
Line: 495
Char: 4
Error: Type mismatch: 'Cint'
Code: 800A000D
Source: Microsoft VBScript runtime error
OK
Is this a bug with the Say Numbers module or a problem specific to my system?
Also immediately afterwards (before any new calls arrive on same line) copy the .vbs file mentioned in the error (D:\Program Files\VoiceGuide\data\vbs_5_SayNumber.vbs) and post it here as well (as an attachment)
Please place attached file in VoiceGuide's \system\vbs\ subdirectory. Then try running again.
There was a bug in the lib_num2wav.vbs file (which is used by Say Number module to generate the list of sound files to be spoken) which caused it to crash if both a comma and a decimal point were present in the number which was to be spoken.
Attached file fixes this problem.
lib_num2wav.vbs
