Data retrieved from MySQL are all 0
No matter what the number is in mysql database, say number module only give me zero. really drive me nuts.
my operrating system is Winnt 4.0 with myodbc 3.51 driver and mysql 4.0.15 installed. I'm using dialigic 41/h. below is the VG scrrips.
Version=5.0
DefaultModuleDisplayHeight=
StartModule=select
RunAtHangup=
StartWithoutAnswer=0
CtmAsiName=
[select]
Type=Play
DispSize=69
Txt=Play a sound file, then await a response...
PlayFile1=C:\TEMP\voice\enter.wav
Replay=2,5
strTtsText=
on {1} goto [get product code number]
Position=40,48
Type=Get Numbers
DispSize=69
Txt=Play a prompt asking the caller to enter a sequence of numbers, speak the sequence back to the caller and ask them to confirm it. Go down different paths depending on the numbers entered...
Replay=2,5
GetNbrLenEnforce=0
Confirm=OFF
on {success} goto [quantity query]
Position=229,49
[quantity query]
Type=Database Query
DispSize=69
Txt=Search the database for data. You can then use the returned results later in your script (see Result Variables), eg: in the Say Number module or as parameters to the program calles in a Run Program module.
DbDatabase=test
DbUser=
DbConnectString=ODBC;DRIVER={MySQL ODBC 3.51 DRIVER};server=localhost;database=test;user=myusname;password=mypass;port=3306;
DbSql=SELECT products_quantity FROM products WHERE products_id = $RV[get product code number]
on {success} goto [say quantity]
Position=459,50
[say quantity]
Type=Say Numbers
DispSize=69
Txt=Say the number, amount, date or the digits. See the list o options to see how the number supplied can be interpreted and spoken out...
PlayFile2=$RV[quantity query]
Replay=2,5
SayNbrType=Number
Position=463,149
below is log file:
select 1
get product code number 6
quantity query_RowCount 1
Hangup time 4/24/04
in mysql the products_id and products_quantity are INT type.
give me help please!
Looking at the script I'd say that you're using an incorrect Result Variable in the module [say quantity]
Please read the "Query Results" section of the "DB Query Module" entry in VoiceGuide Help file. Online copy of relevant page is here:
http://www.voiceguide.com/vghelp/html/modDbQuery.htm
Right now in [say quantity] module you are using "$RV[quantity query]" - you should be using $RV[ModuleTitle_ColumnIndex_RowIndex]
eg:
$RV[quantity query_1_1]
If you are still having problems after making the change could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong.
