Frank.Schwarz Report post Posted 04/26/2024 12:22 PM Hello, we are testing voiceguide with an evaluation license. The test call is always stopping after 36s. Is this normal because of the test license? Share this post Link to post
SupportTeam Report post Posted 04/26/2024 11:04 PM VoiceGuide does not automatically limit length of calls just because the software is running in evaluation mode. If you can post vgEngine/ktTel traces we can see what has happened on the call and advise. There are ways of limiting total length of call - but this would need to have been explicitly set up. Share this post Link to post
Frank.Schwarz Report post Posted 04/30/2024 10:45 AM Hello, logfiles vgEngine and ktTel uploaded. 0430_1231_vgEngine.txt 0430_ktTel.txt Share this post Link to post
SupportTeam Report post Posted 04/30/2024 10:55 PM Traces show the remote side disconnected the call. ktTel trace shows: 423 123325.479 51520 3 1 ev GCEV_DISCONNECTED crn=8000001 q: 3/3 WireShark can also be used to confirm that the disconnect was sent from the other side. Also, the ktTel trace shows that the SIP Register request to register VoiceGuide as extension 802 on PBX at 192.168.24.124 failed. Please see ktTel excerpt below: 171 123131.727 51520 WARN IPEC_REG_FAIL_serverResponseDataMismatch : there was a mismatch between the internal IP CCLib data, and the data contained in the Registrar's response. 172 123131.727 51520 WARN ********************************************** 173 123131.727 51520 WARN SIP_REGISTER Failed 174 123131.727 51520 WARN ********************************************** 175 123131.727 51520 NOTE Most likely the Contact: field in Registrar's response was different then the Contact: field in the Register request sent out by VoiceGuide. 176 123131.727 51520 NOTE Some SIP Registrars ignore the Contact: field sent to them and set their own instead. 177 123131.727 51520 NOTE Please use WireShark to confirm contents of the SIP Registraton messages exchanged. 178 123131.727 51520 NOTE Please set the LocalAlias field in VoiceGuide's Config.xml to match the Contact: field in Registrar's responses. 179 123131.727 51520 NOTE ********************************************** Share this post Link to post
