Guest Manuel Gallego Report post Posted 04/26/2004 08:30 AM I have voiceguide 5.2.1011 installed with a dialogic D/4pci I am using an script similar to collections, where dialler id is searched in a database. But the variable $RV_CALLEDNUMBER have not caller phone number so i get always same answer: "We have been unable to find the entry for telephone number" This is the trace: 102450,89 14 linedevstate 2048 0 0 102450,89 14 callstate OFFERING 66203 0 4 102450,90 14 Answer the call at 26/04/2004 10:24:50 102450,91 14 lineAnswer(66203) => 66169 102450,91 14 callinfo CALLEDID 102450,92 14 callinfo ORIGIN 102450,92 14 ring 0 102451,44 14 callstate CONNECTED 66203,1,0 102451,44 14 WorkingModeTAPI@Connected= 102451,45 14 WorkingModeScript@Connected= 102451,48 14 Inband detection not enabled 102451,49 14 StartLoadedVgs at 26/04/2004 10:24:51 102451,49 14 rv add [$RV_STARTTIME]{26/04/2004 10:24:51} 102451,49 14 rv add [$RV_DEVICEID]{14} 102451,50 14 rv add [$RV_CIDNAME]{} 102451,50 14 AddRVns [PathApp]{C:\apps\voiceguide\} 102451,50 14 rv add [$RV_CIDNUMBER]{} 102451,51 14 tapi Reply (LineEvReply) ok 66169 0 102451,51 14 TimeoutClear 102451,52 14 [GetClientRecord] DB Query 102451,52 14 callinfo MONITORMODES 102451,53 14 db Jet mode used (To use ODBC mode specify ODBC Connect string) 102451,54 14 RVreplace start: [sELECT Name, AccountBalance FROM Clients WHERE PhoneNumber=$RV_CALLEDNUMBER] 102451,55 14 RVns [PathSysVoice]{C:\apps\voiceguide\system\voice\}[PathApp]{C:\apps\voiceguide\}[PathDataVm]{C:\apps\voiceguide\data\}[PathVgSys]{C:\apps\voiceguide\system\}[$RV_STARTTIME]{26/04/2004 10:24:51}[$RV_DEVICEID]{14}[$RV_CIDNAME]{}[PathApp]{C:\apps\voiceguide\}[$RV_CIDNUMBER]{} 102451,56 14 RVreplace end: [sELECT Name, AccountBalance FROM Clients WHERE PhoneNumber=''] 102451,57 14 db About to execute a Retrieve type operation [sELECT Name, AccountBalance FROM Clients WHERE PhoneNumber=''] 102451,58 14 db [GetClientRecord] movelast err : No hay ningún registro activo. 102451,61 14 TimeoutClear 102451,61 14 [ClientNotFound] Playing 102451,62 14 RVreplace start: [We have been unable to find the entry for telephone number $RV_CALLEDNUMBER] 102451,63 14 RVns [PathSysVoice]{C:\apps\voiceguide\system\voice\}[PathApp]{C:\apps\voiceguide\}[PathDataVm]{C:\apps\voiceguide\data\}[PathVgSys]{C:\apps\voiceguide\system\}[$RV_STARTTIME]{26/04/2004 10:24:51}[$RV_DEVICEID]{14}[$RV_CIDNAME]{}[PathApp]{C:\apps\voiceguide\}[$RV_CIDNUMBER]{} 102451,64 14 RVreplace end: [We have been unable to find the entry for telephone number ] 102451,65 14 tts generate start[We have been unable to find the entry for telephone number ] 102451,66 14 tts generate wait 102451,67 14 RunModule PLAY end 102451,74 14 tts generate finish 102451,74 14 [ClientNotFound] Playing (C:\apps\voiceguide\data\tts14.wav) 102451,77 14 PlaySoundStart ok [C:\apps\voiceguide\data\tts14.wav] 102451,77 14 TimeoutClear 102451,78 14 wa(3759,37335000) 102451,79 14 callinfo MONITORMODES 102455,55 14 wb(37335000) 102455,61 14 Play End line[14] (id=373350) 102455,62 14 ScriptEventCode 8001 iLineState=1100 102455,62 14 LsPlayMsg EV_PLAY_FINISHED 102455,63 14 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG 102457,14 14 callstate DISCONNECTED 66203,0,0 102457,14 14 ScriptEventCode 9250 iLineState=1101 102457,15 14 LsPlayMsgFinished EV_REMOTEPARTY_DISCONNECT 102457,16 14 rv add [Hangup Time]{26/04/2004 10:24:57} 102457,17 14 Hanging up call... 102457,17 14 RecSoundStop ok 102457,18 14 PlaySoundStop err=0 102457,19 14 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 102457,20 14 fnHangupCall end 102457,23 14 linedevstate 2048 0 0 102457,24 14 callstate IDLE 66203 0 0 102457,25 14 WorkingMode@Idle= 102457,26 14 TimeoutClear 102457,26 14 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE 102457,27 14 tapi Reply (LineEvReply) ok 66152 0 102458,20 14 Timer fired EV_TIMEOUT_TIMETOREINITLINE 102458,20 14 ScriptEventCode 9008 iLineState=900 102458,21 14 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 102458,22 14 ReinitTelephony due to IDLE 102458,23 14 tapic lineDeallocateCall(MainCall:66203) 0 102458,39 14 lineOpen(14)=> 102458,39 14 Waiting for a call... 102458,40 14 LineHandle=66135 102458,41 14 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 102501,41 14 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 102501,41 14 ScriptEventCode 9013 iLineState=900 Share this post Link to post
SupportTeam Report post Posted 04/26/2004 09:20 PM Is Caller ID information sent by the telephone company? If it is you should wait till after second ring to answer the call - Caller ID information is sent from phone company between the first and the second ring. also: you should be using $RV_CIDNUMBER. $RV_CALLEDNUMBER is defined only on outbound calls. (see http://www.voiceguide.com/vghelp/html/Resu...ltVariables.htm ) you can see in the trace what RVs are defined by looking at the contents of the trace lines which begin with "RVns". Share this post Link to post
Guest Manuel Gallego Report post Posted 04/28/2004 01:58 PM Yes phone number is sent by phone company, i am using an isdn line. I have used $RV_CIDNUMBER too and i put wait 3 rings still not work 155517,08 14 linedevstate 2048 0 0 155517,08 14 callstate OFFERING 66413 0 4 155517,10 14 callinfo CALLEDID 155517,11 14 callinfo ORIGIN 155517,11 14 ring 0 155523,19 14 ring 2 155529,21 14 ring 3 155529,22 14 Answer the call at 28/04/2004 15:55:29 155529,22 14 lineAnswer(66413) => 66430 155529,77 14 callstate CONNECTED 66413,1,0 155529,77 14 WorkingModeTAPI@Connected= 155529,77 14 WorkingModeScript@Connected= 155529,81 14 Inband detection not enabled 155529,81 14 StartLoadedVgs at 28/04/2004 15:55:29 155529,82 14 rv add [$RV_STARTTIME]{28/04/2004 15:55:29} 155529,82 14 rv add [$RV_DEVICEID]{14} 155529,83 14 rv add [$RV_CIDNAME]{} 155529,83 14 AddRVns [PathApp]{C:\apps\voiceguide\} 155529,84 14 rv add [$RV_CIDNUMBER]{} 155529,84 14 tapi Reply (LineEvReply) ok 66430 0 155529,85 14 callinfo MONITORMODES 155529,86 14 TimeoutClear 155529,86 14 [GetClientRecord] DB Query 155529,87 14 db Jet mode used (To use ODBC mode specify ODBC Connect string) 155529,89 14 RVreplace start: [sELECT Name, AccountBalance FROM Clients WHERE PhoneNumber=$RV_CIDNUMBER] 155529,89 14 RVns [PathSysVoice]{}[PathApp]{C:\apps\voiceguide\}[PathDataVm]{C:\apps\voiceguide\data\}[PathVgSys]{C:\apps\voiceguide\system\}[$RV_STARTTIME]{28/04/2004 15:55:29}[$RV_DEVICEID]{14}[$RV_CIDNAME]{}[PathApp]{C:\apps\voiceguide\}[$RV_CIDNUMBER]{} 155529,90 14 RVreplace end: [sELECT Name, AccountBalance FROM Clients WHERE PhoneNumber=''] 155529,91 14 db About to execute a Retrieve type operation [sELECT Name, AccountBalance FROM Clients WHERE PhoneNumber=''] 155529,92 14 db [GetClientRecord] movelast err : No hay ningún registro activo. 155529,93 14 TimeoutClear 155529,93 14 [ClientNotFound] Playing 155529,94 14 RVreplace start: [We have been unable to find the entry for telephone number $RV_CALLEDNUMBER $RV_CIDNUMBER] 155529,95 14 RVns [PathSysVoice]{}[PathApp]{C:\apps\voiceguide\}[PathDataVm]{C:\apps\voiceguide\data\}[PathVgSys]{C:\apps\voiceguide\system\}[$RV_STARTTIME]{28/04/2004 15:55:29}[$RV_DEVICEID]{14}[$RV_CIDNAME]{}[PathApp]{C:\apps\voiceguide\}[$RV_CIDNUMBER]{} 155529,96 14 RVreplace end: [We have been unable to find the entry for telephone number ] 155529,97 14 tts generate start[We have been unable to find the entry for telephone number ] 155529,97 14 tts generate wait 155529,98 14 RunModule PLAY end 155530,09 14 tts generate finish 155530,09 14 [ClientNotFound] Playing (C:\apps\voiceguide\data\tts14.wav) 155530,12 14 PlaySoundStart ok [C:\apps\voiceguide\data\tts14.wav] 155530,13 14 TimeoutClear 155530,14 14 wa(3764,9369900) 155530,15 14 callinfo MONITORMODES 155533,96 14 Play End line[14] (id=93699) 155533,97 14 ScriptEventCode 8001 iLineState=1100 155533,97 14 LsPlayMsg EV_PLAY_FINISHED 155533,98 14 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG 155536,87 0 sys cleanup Start 155536,87 0 sys cleanup End 155538,90 14 Timer fired EV_TIMEOUT_REPLAYMSG 155538,91 14 ScriptEventCode 9005 iLineState=1101 155538,91 14 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG 155538,92 14 tts generate reuse 155538,93 14 [ClientNotFound] Playing (C:\apps\voiceguide\data\tts14.wav) 155538,94 14 PlaySoundStart ok [C:\apps\voiceguide\data\tts14.wav] 155538,95 14 TimeoutClear 155538,95 14 wa(3764,10253100) 155538,96 14 callinfo MONITORMODES 155540,27 14 callstate DISCONNECTED 66413,0,0 155540,28 14 ScriptEventCode 9250 iLineState=1100 155540,29 14 LsPlayMsg EV_REMOTEPARTY_DISCONNECT 155540,29 14 rv add [Hangup Time]{28/04/2004 15:55:40} 155540,30 14 Hanging up call... 155540,31 14 RecSoundStop ok 155540,36 14 PlaySoundStop err=0 155540,37 14 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 155540,38 14 fnHangupCall end 155540,43 14 linedevstate 2048 0 0 155540,43 14 callstate IDLE 66413 0 0 155540,44 14 WorkingMode@Idle= 155540,45 14 TimeoutClear 155540,46 14 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE 155540,46 14 tapi Reply (LineEvReply) ok 66379 0 155541,39 14 Timer fired EV_TIMEOUT_TIMETOREINITLINE 155541,41 14 ScriptEventCode 9008 iLineState=900 155541,41 14 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 155541,41 14 ReinitTelephony due to IDLE 155541,43 14 tapic lineDeallocateCall(MainCall:66413) 0 155541,59 14 lineOpen(14)=> 155541,59 14 Waiting for a call... 155541,59 14 LineHandle=66396 155541,61 14 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 155544,62 14 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 155544,62 14 ScriptEventCode 9013 iLineState=900 Share this post Link to post
SupportTeam Report post Posted 04/28/2004 09:25 PM Yes phone number is sent by phone company, i am using an isdn line. I have used $RV_CIDNUMBER too and i put wait 3 rings still not work 155517,08 14 linedevstate 2048 0 0 155517,08 14 callstate OFFERING 66413 0 4 155517,10 14 callinfo CALLEDID 155517,11 14 callinfo ORIGIN 155517,11 14 ring 0 155523,19 14 ring 2 155529,21 14 ring 3 How can you be using an ISDN when you are using a D/4PCI card? D/4PCI is for analog lines. It looks like the D/4PCI is not picking up the CallerID information - how have you confirmed that CallerID id sent on the line? Do you have another device attached to this line which is picking up the CallerID? Which country are you in and in what format does your phone company send the CallerID? Share this post Link to post
Guest Manuel Gallego Report post Posted 04/28/2004 10:53 PM Oh sorry i forgot! I am using ISDN but i am using analog lines of my PBX. So what should i do to get caller number? Change my dialogic card? what is the cheaper card that can i use? can i change configuration of my pbx to allow send caller id? I am at Spain. Share this post Link to post
SupportTeam Report post Posted 04/28/2004 11:24 PM PBXs do not send the CallerID info between the 1st and 2nd ring like phone companies do. Does your PBX support Inband Signaling or some other form of CTI interfaces? you should speak with your PBX supplier and ask them how PBX can send Caller ID to IVR and see what they say. (What PBX are you using?) Share this post Link to post
Guest It support CTI,dunno about inban Report post Posted 04/29/2004 12:28 AM My PBX name is neris 2, it have not many technical details in the manual, but i have check that it supports CTI, i dunno about inband signaling, but can you tell me how can i trace this information to study and check what pattern is being sent to program properly voiceguide and get called id. THank you! Share this post Link to post
SupportTeam Report post Posted 04/29/2004 01:38 AM From VG Help file: Inband Signaling is sent using a series of DTMF tones immediately after the call is answered. It is only sent to the recipient of the call and it does not matter after how many rings the call is answered - the signaling tones are sent immediately after call answer. It is easy to check if Inband Signaling is sent on the line: place an extension headset against your ear and keep the 'handset on hook' switch depressed so that that handset can accept calls, then make a call to that extension and when the call arrives lift the hand off the 'handset on hook' switch - if there is any Inband Signaling sent you will hear it then a quick series of DTMF tones. (You will not be able to hear the tones usually if you just normally pick up the handset as the playing of the tones would have finished by the time you raise the handset to your ear...) To capture what tones are being sent on the line just set up a VoiceGuide script whose first module is a "Get Numbers" type module - that module will then capture the sent digits and what it captures will be stored in the Log File. Share this post Link to post
AntonB Report post Posted 04/29/2004 05:46 AM Hi, What is ACD software that you recomend to have a best integration with VG? I'm using VG 5.2.1, Dialogic D4/PCI and Panasonic PBX's / Siemen Hicom 3000 Thanks Anton Share this post Link to post
SupportTeam Report post Posted 04/29/2004 06:57 AM ACD system is usually independent of IVR. We haven't really got a recommendation of one over another. Which ones are on your shortlist? It is possible to use VoiceGuide to implement an ACD system, see: http://voiceguide.com/forums/index.php?showtopic=1462 You really do need a CTI interface to implement this though... Share this post Link to post
Guest log files with captured tones. w Report post Posted 04/29/2004 12:38 PM I have made that script with the getnumber module and log files is this, but where is located the tones: 143347,56 14 linedevstate 2048 0 0 143347,56 14 callstate OFFERING 65967 0 4 143347,58 14 callinfo CALLEDID 143347,58 14 callinfo ORIGIN 143347,59 14 ring 0 143347,59 14 Answer the call at 29/04/2004 14:33:47 143347,59 14 lineAnswer(65967) => 65968 143348,13 14 callstate CONNECTED 65967,1,0 143348,13 14 WorkingModeTAPI@Connected= 143348,14 14 WorkingModeScript@Connected= 143348,17 14 Inband detection not enabled 143348,17 14 StartLoadedVgs at 29/04/2004 14:33:48 143348,17 14 rv add [$RV_STARTTIME]{29/04/2004 14:33:48} 143348,18 14 rv add [$RV_DEVICEID]{14} 143348,18 14 rv add [$RV_CIDNAME]{} 143348,19 14 AddRVns [PathApp]{C:\apps\voiceguide\} 143348,19 14 rv add [$RV_CIDNUMBER]{} 143348,20 14 tapi Reply (LineEvReply) ok 65968 0 143348,20 14 callinfo MONITORMODES 143348,21 14 TimeoutClear 143348,21 14 [Get Numbers 2] Number Input 143348,22 14 [Get Numbers 2] Playing () 143348,23 14 ScriptEventCode 8001 iLineState=1300 143348,23 14 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 143348,24 14 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG 143353,16 14 Timer fired EV_TIMEOUT_REPLAYMSG 143353,16 14 ScriptEventCode 9005 iLineState=1301 143353,17 14 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG 143353,18 14 [Get Numbers 2] Playing () 143353,18 14 ScriptEventCode 8001 iLineState=1300 143353,19 14 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 143353,20 14 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG 143358,20 14 Timer fired EV_TIMEOUT_REPLAYMSG 143358,20 14 ScriptEventCode 9005 iLineState=1301 143358,21 14 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG 143358,23 14 [Get Numbers 2] Playing () 143358,23 14 ScriptEventCode 8001 iLineState=1300 143358,23 14 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 143358,25 14 TimeoutSet 10 EV_TIMEOUT_HANGUP 143358,25 14 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 143358,82 14 callstate DISCONNECTED 65967,0,0 143358,82 14 ScriptEventCode 9250 iLineState=1301 143358,82 14 LsGetNbrsRxDigits EV_REMOTEPARTY_DISCONNECT 143358,84 14 rv add [Get Numbers 2]{} 143358,84 14 rv add [Hangup Time]{29/04/2004 14:33:58} 143358,85 14 Hanging up call... 143358,86 14 RecSoundStop ok 143358,86 14 PlaySoundStop err=0 143358,87 14 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 143358,88 14 fnHangupCall end 143358,92 14 linedevstate 2048 0 0 143358,93 14 callstate IDLE 65967 0 0 143358,94 14 WorkingMode@Idle= 143358,95 14 TimeoutClear 143358,95 14 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE 143358,96 14 tapi Reply (LineEvReply) ok 66189 0 143359,89 14 Timer fired EV_TIMEOUT_TIMETOREINITLINE 143359,89 14 ScriptEventCode 9008 iLineState=900 143359,90 14 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 143359,91 14 ReinitTelephony due to IDLE 143359,92 14 tapic lineDeallocateCall(MainCall:65967) 0 143400,08 14 lineOpen(14)=> 143400,08 14 Waiting for a call... 143400,09 14 LineHandle=66224 143400,10 14 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 143403,10 14 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 143403,11 14 ScriptEventCode 9013 iLineState=900 Share this post Link to post
SupportTeam Report post Posted 04/29/2004 01:43 PM ... looks like no Inband Signalling is sent. It is easy to check if Inband Signaling is sent on the line: place an extension headset against your ear and keep the 'handset on hook' switch depressed so that that handset can accept calls, then make a call to that extension and when the call arrives lift the hand off the 'handset on hook' switch - if there is any Inband Signaling sent you will hear it then a quick series of DTMF tones. Do you hear any tones sent by the PBX when you do the above? Share this post Link to post
Guest You told me that its possible us Report post Posted 04/29/2004 03:10 PM But you that in addition to inband signalling its possible to get that dtmf codes using the CTI. So please tell me the another alternative to inband signalling to get codes that have caller id. Thank you Share this post Link to post
SupportTeam Report post Posted 04/29/2004 10:02 PM ... you should really speak to your PBX supplier to see what options are available on your PBX. Share this post Link to post
Guest Manuel Gallego Report post Posted 04/29/2004 10:18 PM Inband signalling is not available at my PBX but it support CTI and TAPI. Please tell me how can investigate by myself what protocol is using my PBX to send caller id. THank you Share this post Link to post
SupportTeam Report post Posted 04/29/2004 10:28 PM You should speak to your PBX supplier to see what type of CTI interface is available on your PBX. As each PBX has slightly different CTI the PBX people should also supply you with some documentation on how to use the CTI interface. Share this post Link to post
Guest PBX supplier told that my PBX no Report post Posted 04/30/2004 01:20 PM I called to my PBX supplier and told me that my PBX Netcom neris 2 is not sending this information throught analog extensions, only throught digital extensions, but i think this information can not very accurate, so i would like to know if there is any application to trace this dtmf codes and check whats going on and if this information is really not sent by my PBX. In case my PBX is not sending that information i think i have to buy another dialogic or telefony cards that accept digital lines, can you recommend me the cheaper option, because i have already waste 500 US$ with a Dialogic D/4PCI. THank you Share this post Link to post
SupportTeam Report post Posted 04/30/2004 02:45 PM Inband Signalling is only used on analog lines... It sounds like your PBX does not have any CTI or Inband Signaling capability... Share this post Link to post
Guest caller id avaiable at my isdn Report post Posted 04/30/2004 04:10 PM Ok then it looks that i have to buy another dialogic or telefony cards that accept digital lines because if i use digital line, called id is available, so can you recommend me the cheaper option, because i have already waste 500 US$ with a Dialogic D/4PCI. Share this post Link to post
SupportTeam Report post Posted 04/30/2004 09:44 PM Please see: http://www.voiceguide.com/suppRecomHardware.htm There are no cards that attach to PBX 'digital extensions' as digital extensions run on propriety protocols. (can the PBX supplier tell you what is the communication protocol used on your PBX's digital extension?) If you have a T1 or an E1 ISDN line then you could attach D/240 or D/300 card to that line. If you have a BRI ISDN line then you could attach one of the CAPI compatilbe cards to that line (see: http://www.voiceguide.com/suppRecomHardware.htm ) Share this post Link to post
Guest Manuel Gallego Report post Posted 04/30/2004 10:41 PM My PBX supplier is an spanish telecom company where technicians are not very qualified and can not give this information. I have tried already to ask about that with no luck. Share this post Link to post
SupportTeam Report post Posted 05/01/2004 08:08 AM ... I'd suggest speaking to the PBX manufacturer then to see what this PBX does and does not support... Share this post Link to post
Guest Guest_Chris Report post Posted 05/11/2004 05:13 PM There care a couple of Dialogic cards that are specifically made to integrate with various PBX systems. Search intel's site for D/82JCT-U. That will work great with a wide variety of phone systems. Share this post Link to post
SupportTeam Report post Posted 05/11/2004 10:18 PM VoiceGuide works with D/82JCT - it is on the Recommended Hardware list. Share this post Link to post
