Guest mazed Report post Posted 04/27/2004 03:23 AM guys, any reccomended hardware that will support this protocol. Physical Configuration: E1 configuration = 31 channels (31 timeslots) Framing = CRC-4 Coding Method = HDB3 Signalling = ISUP Signalling Configuration: Signalling via Point Code Network Indicator = 3 (NA1) thanks. Share this post Link to post
SupportTeam Report post Posted 04/27/2004 07:52 AM Will this line be running ISDN or CAS/Robbed bit ? If ISDN then which protocol will it be using? Share this post Link to post
Guest mazed Report post Posted 05/04/2004 05:59 AM It will not use ISDN nor CAS. the line will be running on SS7 protocol (ITU-T White book standard). Share this post Link to post
SupportTeam Report post Posted 05/04/2004 09:30 AM VoiceGuide does not support SS7 signaling. Share this post Link to post
Guest marktweyn Report post Posted 05/25/2004 11:17 AM is there any plan on supporting this SS7 protocol ? any beta version that support this ? thanks Share this post Link to post
SupportTeam Report post Posted 05/25/2004 10:36 PM Apparently only small changes are required to "VoiceGuide for ISDN" to allow it to work on Dialogic's new SS7 cards, eg: SS7HDP - D4TE which has: • 4 Software selectable T-1 or E-1 interfaces • Supports up to 64 SS7 links • Messaging throughput in excess of 20,000 (MSU) per second over up to64 links see: http://www.intel.com/network/csp/products/8640web.htm I am told that for a significant order we would be able to add the SS7 functionality to VG. Please contact sales@voiceguide.com and they can discuss this with your further. Share this post Link to post
