Guest Mike Report post Posted 04/27/2004 02:48 PM How do I set a minimum record time? I modified VG.INI to "RecLengthMin=30" (I assume for 3 seconds), restarted VoiceGuide, but was still able to leave a 1/2 second message. Share this post Link to post
SupportTeam Report post Posted 04/27/2004 09:54 PM Which version of VG are you using? Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong. (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call.) Share this post Link to post
Guest Guest Report post Posted 04/28/2004 11:51 AM Version is 5.2.1009 Professional. I have logging enabled, so I cut out the portion from a test call and attached it here. foo.txt Share this post Link to post
SupportTeam Report post Posted 04/29/2004 12:22 AM In v5.0 onwards the RecLengthMin setting no longer applies and should have been deleted from VG.INI file - there is a different way of checking record length in v5: The supplied trace shows how long the recorded file is (over 6 seconds long), and also shows us some new Result Variables which have been set by the system: 114708.62 0 [Rec GMPNiteNoPt1] Recording 114710.16 0 LsRecPlayBeep EV_PLAY_FINISHED 114710.50 0 RecSoundStart file[C:\Call Off\GMPNiteNoPt1.wav] ok ... 114716.50 0 dtmf # (66044,35,2) 114716.54 0 rec length RV: Rec GMPNiteNoPt1_RecLen100ms = 62 114716.54 0 rv add [Rec GMPNiteNoPt1_RecLen100ms]{62} 114716.55 0 rv add [Rec GMPNiteNoPt1_EndRecCause]{#} The recording length is now available using the _RecLen100ms Result Varaible: From VG Help file: $RV[ModuleTitle_RecLen100ms] will store the recording length in 100ms units (eg. a value of 75 equals seven and a half seconds). Please use $RV[Rec GMPNiteNoPt1_RecLen100ms] in your script in an Evaluate Expression module to determine whether the recorded message is long enough or not. eg: in Evaluate Expression module use: $RV[Rec GMPNiteNoPt1_RecLen100ms] > 30 and if expression is True the you have a recording longer then 3 seconds... If it turns out that the recorded file is not long enough then you can delete the recorded file using this vb script: Set fso = CreateObject("Scripting.FileSystemObject") On Error Resume Next 'up to 3 deletion attempts for i = 1 to 3 if fso.FileExists("$RV[Rec GMPNiteNoPt1]") = True then fso.DeleteFile "$RV[Rec GMPNiteNoPt1]", True else Set fso = Nothing WScript.Quit end if WScript.Sleep 100 next Set fso = Nothing Share this post Link to post
Guest Mike Report post Posted 04/29/2004 12:03 PM In v5.0 onwards the RecLengthMin setting no longer applies and should have been deleted from VG.INI file That explains why it wasn't working. Please use $RV[Rec GMPNiteNoPt1_RecLen100ms] in your script in an Evaluate Expression module to determine whether the recorded message is long enough or not Works great, thanks! Share this post Link to post
