IMSI number or Telco type
 hello support ,
kindly assit,  how do we get or know which RV, stores  the IMSI number  to network(telco) type. in  out going call,
thanks
Please explain in more detail what you are trying to achieve, and describe in detail your current setup.
Are you using a VoIP/SIP system?
Are those SIP trunks connected straight to a Telco?
Are the SIP trunks the only connection you have with your Telco or do you also have access to some of the Telco's APIs or databases ?
What type of solution are you trying to deploy? What is this IVR system going to be doing?
hello,
Please explain in more detail what you are trying to achieve, and describe in detail your current setup?.
- We want to integrate VG to our payment service application
Current setup for outgoing calls -
A call is made ,
⁃ play a sound - to request the callee to enter a digit
⁃ On say digit 1 , a web service is called to the payment app for an action ,
⁃ On success ,
⁃ A call back to VG is for a sound and SMS sent to the callee.
{ To enable the WS Call the  prompt for payment , the callee network/Telco type (eg 22345 and 22355,  223 is country code and 45 & 54 for network type . How do we get or how does the VG stores that info . }
Yes, SIP
Yes , via an SBC.
Sip trunks only .
Deploy a fund raising solution using the IVR system ,
Thanks.
Sure,
however , to enable the WS  choose the right payment prompt, the  network type , as per the example i gave need to be captured ,  how do we achieve this please?
&RV_DIALEDNUMBERS ,  stores  the whole number dailied  e.g., 223456xxxxxx, but we need only "45".
?  which module helps to return  a call to the VG  on success  from a WS
For simple string manipulation that can be done in a single command you can just use an Evaluate Expression module
see: https://www.voiceguide.com/vghelp/source/html/modevalexpr.htm and look at the String Functions section lower down that page.You need to use the "Mid" function.
eg: to return 2 characters starting at position 4 you would use this in the Evaluate Expression module:
Mid($RV_DIALEDNUMBER,4,2)
If you want to perform more complex operations you can use the Run Script module: https://www.voiceguide.com/vghelp/source/html/modvbs.htm
You just set a Success path from the Web Service module to whatever module you want the IVR callflow to run next.
eg. something like this in the Paths tab of the module:
on {Success} goto [Say Payment Processed OK]
with "Say Payment Processed OK" replaced with title of your own module.
from https://www.voiceguide.com/vghelp/source/html/modws.htm :
Paths
The following are valid path options:
  • Success/Fail
  • HTTP Response Codes
  • Timeout
eg: The following HTTP Response Code paths are all valid:
on {200} goto [Say all went OK]
on {OK} goto [Say all went OK]
on {406} goto [Say trans not accepted]
on {Not Acceptable} goto [Say trans not accepted]
$RV[moduleTitle_PathTaken]
Stores which path was taken when exiting the module.
Thanks much.   meaning  VG only captures the "whole number" , i.e. callee and caller  numbers?
Yes. If you need just certain parts of the number, then you need to use functions as described above to extract the parts that you want from the $RV_DIALEDNUMBER and $RV_CIDNUMBER
