Guest Femi Ogundimu Report post Posted 03/21/2003 11:29 AM Hello, I have been using Voice Guide for quite some time and it has worked excellently with my modem. But I have always started the Play module. Recently I needed to start with the Get Numbers module and I experienced some problems with the Get Numbers module. The module is listed among the modules that can be used to start a scripts. But when I used it I found that my calls are dropped as soon as the modem picks them up. Pls help me on what could be the possible cause of the error as the Get Numbers module never allows my scripts to run as long as it is the starting script. Thanks. Share this post Link to post
SupportTeam Report post Posted 03/23/2003 12:43 AM Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong. (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call.) Share this post Link to post
Guest Femi Ogundimu Report post Posted 03/24/2003 12:46 PM Hope this will shed more light on the problem Here is my Log Trace output: 70814 0 tapie callstate OFFERING 65962 0 4 70824 0 tapie ring 1 71645 0 tapie ring 2 71655 0 Answer the call 71655 0 lineAnswer(65962) => 65945 71655 0 tapie callstate ACCEPTED 65962 0 0 72927 0 tapi Reply 65945 0 72947 0 tapie callstate CONNECTED 65962,0,0 72947 0 WorkingModeTAPI= 72957 0 WorkingModeScript= 72987 0 TimeoutClear 72987 0 Hanging up call... 72987 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 72997 0 PlaySoundStop ok 72997 0 fnHangupCall end 73237 0 tapie callstate DISCONNECTED 65962,1,0 73237 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT 73247 0 PlaySoundStop ok 73247 0 Hanging up call... 73247 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 73257 0 PlaySoundStop ok 73267 0 fnHangupCall end 73277 0 tapie callstate IDLE 65962 0 0 73287 0 WorkingMode@Idle= 73297 0 TimeoutClear 73327 0 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE 73327 0 tapi Reply 65928 0 73337 0 tapi Reply 65911 0 74249 0 Timer fired EV_TIMEOUT_TIMETOREINITLINE 74249 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 74259 0 Initialise telephony (due to IDLE) 74279 0 tapic lineDeallocateCall(MainCall:65962) 0 74569 0 Waiting for a call... 74579 0 hLine=65894 74579 0 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT 79596 0 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT Share this post Link to post
SupportTeam Report post Posted 03/25/2003 12:28 AM OK I see that the system is hanging up the call without even trying to start the script... Can you please post your VG.INI file, and the script (.VGS file) which you are using (or which can demonstrate the problem on your system) I'll have a look at them and see what could be causing this... Share this post Link to post
