Vb Script To Query Db
Is it posible to use VB Script module to perform the database query (currently I'm using db query module but many method could be better if we run DB query within VB Script), if so how to use recordset/row result on another module, a sample script will be appreciated
For information on how to access databases from VBScript I'd recommend you read up on ADO objects (plenty of books on this available). This is a sample of how to insert data:
Set cnn = CreateObject("ADODB.Connection")
cnn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=c:\data\news.mdb"
cnn.Execute "INSERT INTO MyTable (Column1, Column2) VALUES (Value1, Value2);"
cnn.Close
Set cnn = Nothing
Te return data from VBScript back to VoiceGuide use the Run_ResultReturn COM function, see: http://www.voiceguide.com/vghelp/html/com_...esultReturn.htm
Can I access the results with $RV[module title_RowCount] and
$RV[module title_ColumnIndex_RowIndex] if access databases from VBScript Module?
