vatsal Report post Posted 03/21/2003 04:11 PM Has anybody got some definitive settings for British Telecom for the D/4PCI......the settings that came with the modem and/or down load of the site are short of the mark....eg hookfash, was so long the modem effectively hungup. Any help would be greatly appreciated. Regards Vatsal Share this post Link to post
SupportTeam Report post Posted 03/23/2003 12:42 AM Please read the release notes which have come with your card. They usually indicate which Parameter File you should specify in your Dialogic Configuration Manager, and what other settings you should use. If there are no release notes specific to you country it's best to contact the Dialogic distributor in your area for assistance in this matter. The VoiceGuide help file shows how to set the hookflash length on the Dialogic cards. You can also use Dialogic's PBXpert application to specify what type of tone sequence constitutes a busy signal on your telephone system. Share this post Link to post
