Guest cpshuffle Report post Posted 05/03/2004 05:05 PM We are using the ATT Natural Voices Engine in conjuction with Voiceguide. Voiceguide reads text files perfectly. The problem is, that if the text file or variable has too many characters it is cut off. Is there a maximum of characters that tts can handle. If so is there a way around it? Thanks Share this post Link to post
SupportTeam Report post Posted 05/03/2004 08:59 PM Looks like the limit is 1000 characters - you must be doing some fairly long TTS if you are exceeding this - but there is no reason for there to be a limit at all - we should be able to issue an update for you within a couple of days which will not have such a limit. Share this post Link to post
Guest cpshuffle Report post Posted 05/03/2004 09:36 PM Thank You, We would really appreciate an update to override the tts character limit Let me know when it is ready Stan Share this post Link to post
SupportTeam Report post Posted 05/09/2004 03:54 AM Please place attached OCX in Windows' System32 directory, overwriting existing file, then restart VG. You will now be able to do unlimited length TTS with VoiceGuide. SapiWrap_1.4.zip Share this post Link to post
Guest cpshuffle Report post Posted 05/10/2004 03:30 PM thank you very much Share this post Link to post
SupportTeam Report post Posted 05/10/2004 10:32 PM This OCX is part of the v5.2.2 release onwards. Share this post Link to post
