Guest Merzik Agaiby Report post Posted 05/04/2004 06:47 AM We are developing an IVR system and we need to play back the number in arabic language, note that the sequance of numbers in arabic language is different from English. Is there any way to make that, if not can I make a custom module to make that. Share this post Link to post
SupportTeam Report post Posted 05/04/2004 11:48 PM From VG Help file's section on "Say Number" module: Need to change the way Say Number module speaks Amounts ? Users can edit the way in which the numbers are spoken, or even add their own Say Number functions by editing the file: lib_num2wav.vbs located in VoiceGuide's \system\vbs\ subdirectory. This is useful if it is required to say numbers/amounts in a language other then English. Please read the lib_num2wav.vbs file for more information. If you have problems creating your own speak-numbers function in this module then please post the VBS code you have generated and a description of what you want to achieve and we can then offer more assistance. Share this post Link to post
Guest Merzik Agaiby Report post Posted 05/05/2004 12:00 PM I make some changes in lib_num2wav.vbs but the say number is does not work? I post the lib_num2wav.vbs and I need your help. lib_num2wav.vbs Share this post Link to post
SupportTeam Report post Posted 05/05/2004 12:19 PM Could you please post a copy of VoiceGuide's Debug Printout which captures the call, this will allow us to see what is going wrong. When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call. Share this post Link to post
Guest Guest_Rajendra Prasad Report post Posted 05/11/2004 06:19 AM Hello Friend, I've written a vb script for Indian number system (Hindi) and it is working fine in Voice Guide. You may also write for your language. Break the whole number in valu and their position in your number system. Rajendra Prasad rajendrarajsri@yahoo.co.in Share this post Link to post
saleh Report post Posted 08/20/2004 09:51 AM have you been able tp play arabic numbers in the correct way? i have a project, we need to support the arabic language, can you share your work with me? Share this post Link to post
SupportTeam Report post Posted 08/20/2004 09:56 PM What specific problem are you encountering? Have you tried adding your own functions to the lib_num2wav.vbs file? Share this post Link to post
