Guest Important help Report post Posted 05/05/2004 10:31 AM i have a problem i'm using dialogic card with the vg and i want to set the hook flash but when i open the control panel i don't find the dialogic service provider listed although i added this option when i was installing the dialogic software Share this post Link to post
SupportTeam Report post Posted 05/05/2004 12:14 PM Have you followed the instructions in the VG Help file: http://www.voiceguide.com/vghelp/html/Dial...llTransfers.htm Share this post Link to post
Guest abeer Report post Posted 05/06/2004 06:32 AM yes i followed the instructions but in the part of setting the hookflash length on the dialogic card this says that i have to open the control panel "phone and modem options"advanced tab and select the dialogic service provider well i did not find any dialogic service provider shown and when i try to add a no service providers found is shown that is although when i tried to install the dialogic software i selected that the TAPI is installed Share this post Link to post
SupportTeam Report post Posted 05/06/2004 06:41 AM Which Dialogic System Release version are you using? I'd try re-installing the Dialogic software again. Make sure you select the Global Call option as well. Share this post Link to post
