Guest She Report post Posted 05/08/2004 09:35 AM Hi! I wish to populate a particular html form with values by using a VBScript. I wish to do this without having to use an ASP implementation (i.e. I create a vbs file and then when i run it, the html page "included" in the code will be populated with the correct values accordingly. Is this possible? Can I seek for some assistance? Thank you very much. She Share this post Link to post
SupportTeam Report post Posted 05/09/2004 12:46 AM Not too sure how you would do this from VBScript - you should probably look through VBScript references and resources available through Microsoft or online or find some books on the subject. This forum is for answering questions relating directly to VoiceGuide software. Share this post Link to post
