Guest John Report post Posted 05/09/2004 01:48 AM Hi, What is the best way to get the time when the incoming call was finished. (at any time even when call was finished inadvertently) Thank you Share this post Link to post
SupportTeam Report post Posted 05/09/2004 02:30 AM $RV[Hangup Time] This RV is blank while call is active and holds the time of last call end until a new call arrives on the line. To retrieve this value you may want to use the RvGet COM function, see: http://www.voiceguide.com/vghelp/html/com_RvGet.htm Another way is to use an "On Hangup" script, see: http://www.voiceguide.com/vghelp/html/Call...ll%20Finish.htm and from within that script just check what is the current time. Share this post Link to post
