Time when the incoming call was finished
What is the best way to get the time when the incoming call was finished.
(at any time even when call was finished inadvertently)
Thank you
$RV[Hangup Time]
This RV is blank while call is active and holds the time of last call end until a new call arrives on the line.
To retrieve this value you may want to use the RvGet COM function, see:
http://www.voiceguide.com/vghelp/html/com_RvGet.htm
Another way is to use an "On Hangup" script, see:
http://www.voiceguide.com/vghelp/html/Call...ll%20Finish.htm
and from within that script just check what is the current time.
