Read From Txt File
I was able to write to a file and I want to read the the info from the file back. I have VB script with this code: The file that I want to read from has one line in it.
set fileV = fso.OpenTextFile("C:\emailaddress3.txt",ForReading)
sEntireFile = fileV.ReadAll
fileV.close
vg.RvSet $RV_LINEID, "EmailAddress", sEntireFile
set vg = Nothing
set fileV = Nothing
set fso = Nothing
From this code the result of $RV[EmailAddress] ="" instead of the line from the file. Do you see anything wrong with this code?
You would have gotten an error displayed on screen when you ran that VBScript telling you which line is incorrect... this line is wrong:
You are using "ForReading" constant - but have not declared what this constant ought to be (VBScript engine will not declare this constant for you internally).
Use this:
set fileV = fso.OpenTextFile("C:\emailaddress3.txt", 1)
and all should work OK.
