vatsal Report post Posted 03/24/2003 11:36 PM I am having trouble getting the IVG to identify when callerID is WITHHELD. I can clearly see the details in the event trace log, but how do you create an expression when there is no value in the $RV_CIDNUMBER, not even a zero. If the caller has withheld the number, I am looking to ask the caller to manually enter the number. Below is the initial event logs showing the system acknowledging the number is withheld. I have tried a number of expressions using $RV_CIDNUMBER without success. Does anybody have any suggestions. 45716 6 tapie linedevstate 2048 0 0 45716 6 tapie callstate OFFERING 66051 0 4 45746 6 Lev_CallerID [,WITHHELD] 45756 6 tapie callinfo CALLEDID 45756 6 tapie callinfo ORIGIN 45756 6 tapie ring 0 51735 6 tapie ring 2 51735 6 Answer the call Share this post Link to post
SupportTeam Report post Posted 03/25/2003 12:36 AM You can use the Evaluate Expression module, and in the module have the expression: "$RV_CIDNUMBER" = "" The "True" path will be taken if $RV_CIDNUMBER is not set to anything, and the "False" path will be taken if $RV_CIDNUMBER contains some value. You can also use $RV_CIDNAME, which in these cases should be set to "WITHHELD", so you can use the following expression: "$RV_CIDNAME " = "WITHHELD" And if the above is true then the "True" path will be taken... Share this post Link to post
Guest Guest Report post Posted 11/26/2004 05:41 PM is it possible to find out the identity of caller "id withheld"? Share this post Link to post
