$RV_CIDNUMBER - how to use in VBScript & MS Access
Please respond to those questions. Don't transfer me to help link.
I have a couple of questions regarding CIDNUMBER and CIDNAME.
How do I access caller?
wkSheet.Cells(y-1, iColumn+1) = $RV_CIDNUMBER
or
wkSheet.Cells(y-1, iColumn+1) = $RV[CIDNUMBER]
What if $RV_CIDNUMBER is empty.
What kind of value do I get when I try to access $RV_CIDNUMBER
but I don't have caller ID activated through my phone provider.
Is it even possible?
I tried to insert wkSheet.Cells(y-1, iColumn+1) = $RV_CIDNUMBER
to my excell sheet but I got "VB Script compilation error".
Can I access CIDNUMBER at the "Call Finish" module or I have to access it before that.
Thank you
Please post the entire VoiceGuide script which you are using.
$RV_CIDNUMBER is the correct one to use. If no CallerID is available it will be replaced with a blank (empty string).
You can use $RV_CIDNUMBER in the "Call Finish" script.
Error points to dollar sign $
wkSheet.Cells(y-1, iColumn+26) = $RV_CIDNUMBER
Version=5.0
DefaultModuleDisplayHeight=
StartModule=Script
RunAtHangup=
StartWithoutAnswer=0
CtmAsiName=
[script]
Type=Run VB Script
DispSize=69
Txt=Run a VB Script.
VbsFileToRun=
VbsWait=0
VbScript=Dim xlApp, xlBook, xlSht
Dim filename
on error resume next
filename = "X:\Sport.xls"
Set xlApp = CreateObject("Excel.Application")
set xlBook = xlApp.WorkBooks.Open(filename)
set xlSht = xlApp.activesheet
xlApp.DisplayAlerts = False
Call GetToFirstItem(xlSht, 1, "ID")
'Call GetToFirstItem(Sheets("Sheet1"), 1, "ID")
xlBook.Save
xlBook.Close SaveChanges=True
xlApp.Close
xlApp.Quit
'always deallocate after use...
set xlSht = Nothing
Set xlBook = Nothing
Set xlApp = Nothing
Sub GetToFirstItem(wkSheet, iColumn, ColumnStartCaption)
wkSheet.Select
'Range(iColumn & "1").Select
'wkSheet.Range("A1").Select
y = 0
Dim temp
Do Until temp = ColumnStartCaption
y = y + 1
temp = wkSheet.Cells(y, iColumn)
Loop
y = y + 1
Do Until temp = ""
y = y + 1
Loop
wkSheet.Cells(y-1, iColumn+2).NumberFormat = "h:mm:ss;@"
wkSheet.Cells(y-1, iColumn+2) = Hour(Now) & ":" & Minute(Now) & ":" & Second(Now)
wkSheet.Cells(y-1, iColumn+27) = $RV_CIDNAME
End Sub
VbsHoldPlay=
on {success} gosub [X:\Email.vgs|Evaluate]
on {fail} gosub [X:\Email.vgs|Evaluate]
on {timeout 0} gosub [X:\Email.vgs|Evaluate]
Position=100,49
[Phone Message]
Type=Phone Message
DispSize=69
Txt=Schedule a call to be made to a telephone number and run a VG script when the phone is answered.
sDialPhone0=7565128
sDialWelc0=
sDialScript0=X:\Echo.vgs
sDialVariables0=
sDialLineSelection0=
sDialRetry0=0
sDialDelay 0=0
sDialPhone1=
sDialWelc1=
sDialScript1=
sDialVariables1=
sDialLineSelection1=
sDialRetry1=2
sDialDelay 1=5
sDialPhone2=
sDialWelc2=
sDialScript2=
sDialVariables2=
sDialLineSelection2=
sDialRetry2=2
sDialDelay 2=5
Position=113,185
Log File
182650.02 5 linedevstate 2048 0 0
182650.02 5 callstate OFFERING 65965 0 4
182650.02 5 Answer the call at 5/12/2004 6:26:50 PM
182650.03 5 lineAnswer(65965) => 66136
182650.03 5 callinfo CALLEDID
182650.03 5 callinfo ORIGIN
182650.03 5 ring 0
182650.56 5 callstate CONNECTED 65965,1,0
182650.56 5 WorkingModeTAPI@Connected=
182650.56 5 WorkingModeScript@Connected=
182650.59 5 Inband detection not enabled
182650.59 5 StartLoadedVgs at 5/12/2004 6:26:50 PM
182650.59 5 AddRVns [scriptsPath]{X:\}
182650.59 5 rv add [$RV_STARTTIME]{5/12/2004 6:26:50 PM}
182650.59 5 rv add [$RV_DEVICEID]{5}
182650.59 5 rv add [$RV_CIDNAME]{}
182650.59 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
182650.59 5 rv add [$RV_CIDNUMBER]{}
182650.61 5 tapi Reply (LineEvReply) ok 66136 0
182650.61 5 callinfo MONITORMODES
182650.61 5 TimeoutClear
182650.61 5 [Play 1] Playing
182650.61 5 [Play 1] Playing (1\Welcome.wav)
182650.63 5 PlaySoundStart ok [X:\1\Welcome.wav]
182650.63 5 TimeoutClear
182650.63 5 RunModule PLAY end
182650.63 5 wa(2980,16129600)
182650.63 5 callinfo MONITORMODES
182653.63 5 wb(16129600)
182653.67 5 Play End line[5] (id=161296)
182653.67 5 ScriptEventCode 8001 iLineState=1100
182653.67 5 LsPlayMsg EV_PLAY_FINISHED
182653.67 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
182653.67 5 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
182653.67 5 ScriptEventCode 9002 iLineState=1101
182653.67 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
182653.67 5 TimeoutClear
182653.69 5 [Job_Offers] Running vb script:[X:\CallFinishScript.vgs]
182727.11 0 Script Load X:\CallFinishScript.vgs
182727.11 5 Loaded VbsAtHangup into:2
182727.11 5 tapi Reply (LineEvReply) ok 66017 0
182727.11 5 TimeoutClear
182727.11 5 [script] Running VB Script...
182727.11 5 RVreplace start (strlen>500)
182727.11 5 RVns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{X:\}[$RV_STARTTIME]{5/12/2004 6:26:50 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Job_Offers]{False}[Hangup Time]{5/12/2004 6:27:27 PM}
182727.13 5 VBScript Run continuing...
182727.13 5 stack idx=1
182727.13 5 rv add [scriptStart_Time]{5/12/2004 6:27:27 PM}
182727.13 5 rv add [scriptStart_CalledFrom_Script]{X:\CallFinishScript.vgs}
182727.13 5 rv add [scriptStart_CalledFrom_Module]{Script}
182727.13 0 Script Load X:\Email.vgs
182727.14 5 Loaded X:\Email.vgs into:3
182727.16 5 AddRVns [scriptsPath]{X:\}
182727.16 5 TimeoutClear
182727.16 5 [Evaluate] Evaluate [(($RV_HOUR >= 12) and ($RV_HOUR <= 13) and ($RV_MINUTE >= 00) and ($RV_MINUTE <= 30)) or(($RV_HOUR >= 20) and ($RV_HOUR <= 22))]
182727.16 5 RVreplace start: [(($RV_HOUR >= 12) and ($RV_HOUR <= 13) and ($RV_MINUTE >= 00) and ($RV_MINUTE <= 30)) or(($RV_HOUR >= 20) and ($RV_HOUR <= 22))]
182727.16 5 RVns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{X:\}[$RV_STARTTIME]{5/12/2004 6:26:50 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Job_Offers]{False}[Hangup Time]{5/12/2004 6:27:27 PM}[scriptStart_Time]{5/12/2004 6:27:27 PM}[scriptStart_CalledFrom_Script]{X:\CallFinishScript.vgs}[scriptStart_CalledFrom_Module]{Script}[scriptsPath]{X
182727.16 5 RVreplace end: [((18 >= 12) and (18 <= 13) and (27 >= 00) and (27 <= 30)) or((18 >= 20) and (18 <= 22))]
182727.16 5 .Eval(((18 >= 12) and (18 <= 13) and (27 >= 00) and (27 <= 30)) or((18 >= 20) and (18 <= 22)))
182727.16 5 AddRVns [Evaluate_Input]{((18 >= 12) and (18 <= 13) and (27 >= 00) and (27 <= 30)) or((18 >= 20) and (18 <= 22))}
182727.16 5 AddRVns [Evaluate]{False}
182727.16 5 Eval Expr result:[False]
182727.16 5 path {False} not found
182727.16 5 rv add [Hangup Time]{5/12/2004 6:27:27 PM}
182727.16 5 Hanging up call... [No path (False) to next module defined.]
182727.16 5 HangupCall_Common Mode=AfterHangupRun
182727.16 5 ReinitTelephony due to IDLE
182727.17 5 tapic lineDeallocateCall(MainCall:65965) 0
182727.31 5 lineOpen(5)=>
182727.31 5 Waiting for a call...
182727.31 5 LineHandle=66051
182727.31 5 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
182730.48 5 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
182730.48 5 ScriptEventCode 9013 iLineState=900
Have you tried using quotes around the values you are trying to assign the Excel's cells ?
ie: change:
to:
wkSheet.Cells(y-1, iColumn+26) = "$RV_CIDNUMBER"
wkSheet.Cells(y-1, iColumn+27) = "$RV_CIDNAME"
see the example from the VG help file:
http://www.voiceguide.com/vghelp/html/modVbs.htm
Also I notice from the trace (which btw is not from the posted script...) that you are using an Evaluate Expression module to do Time of day based switching - You may want to look at version 5.2 of VG - there is a "Time Switch" module available in that version.
