Dialogic D4pciu Stops Playing Dtmf
When I play back DTMF digits using the Dialogic D4PCIU card, it cuts of the playing around the 30th digit. It did not do this when I originally had a voice modem. A portion of the log where this occurs is below:
020712.48 5 RVreplace end: [*#,*9*1**18005357963*,*7*1*54664258779**,*#,**3*1310*1213*1818*1714**,]
020712.48 5 tapic lineGenerateDigits(65760,*#,*9*1**18005357963*,*7*1*54664258779**,*#,**3*1310*12
3*1818*1714**,,0) => 0
020712.50 5 RunModule PLAY end
020720.70 5 generate LINEGENERATETERM_DONE
020720.70 5 TimeoutSet 1 EV_TAPI_GENERATE
020721.75 5 Timer fired EV_TAPI_GENERATE
020721.75 5 ScriptEventCode 9602 iLineState=1100
020721.75 5 LsPlayMsg EV_TAPI_GENERATE
020721.77 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
020721.77 5 TimeoutSet 20 EV_TIMEOUT_GOTOMODULE
020736.00 0 sys cleanup Start
020736.00 0 sys cleanup End
020743.66 5 Timer fired EV_TIMEOUT_GOTOMODULE
020743.66 5 ScriptEventCode 9002 iLineState=1101
020743.67 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
020743.67 5 TimeoutClear
020743.69 5 [GetConfigCompletionMsgPrompt] DB Query
020743.69 5 db Jet mode used (To use ODBC mode specify ODBC Connect string)
020743.70 5 RVreplace start: [sELECT FileToPlay, PromptText, ModuleName, OptionsFileToPlay FROM qlPromptOptions WHERE LID='$RV[Answer Call]' AND PromptName = 'CompletionMsg']
This would be Dialogic's own internal limit on how many DTMFs it can generate per "play DTMF" call.
Solution is fairly straightforward:
You will need to split the sending of DTMF tones across two or more Play modules.
You can use Evaluate Expression module and its string manipulation functions:
left(), right() and mid(), to split up a long DTMF string into manageable lengths, see: http://www.voiceguide.com/vghelp/html/modEvalExpr.htm
Then save individual DTMF strings into separate RVs and then use those RVs in the Play modules...
I just used the shntool and made a .wav file of the tones with pauses. That seems to work fine. Is there anything I need to keep in mind when doing this?
That solution will work fine as well.
There are no limits on the length of .wav files which you can play with Dialogic cards.
