Problems Answering Calls
have upgraded vg to latest version 5.2.2000 & move from direct lines to Hybrex PABX.
VG runs on win2k sp2 pc as a service using firedaemon software
4 port d4/pci dialogic card
pabx is configured to route calls to vg pc when night switch is activated
functions as a/h customer order recording service, disconnect tone set to C as this is what the Hybrex pabx specs.
end of call has been set in TSP at 425mhz delay 500, 500, C set in vg.ini, C set in script properties
Seems to work ok, but occassionally calls will not be released on 1 line, this seems to cause other calls to be answered intermittently or not all all, after numerous attemps at calling (10) the call is sometimes answered by vg.
not sure if problem with script or tsp / pabx config/ dialogic config, system works fine for a random period then develops symptoms described
Any assistance would be greatly appreciated, I have attached the vg.ini files & script I am using, all seems to be working ok now but this system is for a/h hours customer orders & so must be reliable, previously using 4 direct phone lines & no PABX vg was rock solid, 1 year of operation & no failures. Please help.
trace of successful test call
175155.42 7 linedevstate 2048 0 0
175155.42 7 callstate OFFERING 65980 0 4
175155.44 7 Lev_CallerID [412748488,]
175155.45 7 callinfo CALLEDID
175155.45 7 callinfo ORIGIN
175155.45 7 ring 0
175155.45 7 No old processes from last call (could not obtain handle) 1148, 1700
175155.45 7 Answer the call at 14/05/2004 17:51:55
175155.45 7 lineAnswer(65980) => 65963
175156.00 7 callstate CONNECTED 65980,1,0
175156.00 7 WorkingModeTAPI@Connected=
175156.00 7 WorkingModeScript@Connected=
175156.03 7 Inband detection not enabled
175156.03 7 StartLoadedVgs at 14/05/2004 17:51:56
175156.03 7 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\VPQMCOSYS\}
175156.03 7 rv add [$RV_STARTTIME]{14/05/2004 17:51:56}
175156.03 7 rv add [$RV_DEVICEID]{7}
175156.03 7 rv add [$RV_CIDNAME]{}
175156.03 7 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
175156.03 7 rv add [$RV_CIDNUMBER]{412748488}
175156.03 7 tapi Reply (LineEvReply) ok 65963 0
175156.03 7 callinfo MONITORMODES
175156.03 7 TimeoutClear
175156.05 7 [Welcome] Number Input
175156.05 7 [Welcome] Playing (C:\Program Files\VoiceGuide\Scripts\VPQMCOSYS\welcome.wav)
175156.06 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\VPQMCOSYS\welcome.wav]
175156.06 7 TimeoutClear
175156.06 7 wa(14024,78771800)
175156.06 7 callinfo MONITORMODES
175202.72 7 dtmf 1 (65980,49,2)
175202.72 7 ScriptEventCode 49 iLineState=1300
175202.72 7 LsGetNbrsPlayWelcMsg 1
175202.77 7 PlaySoundStop err=0
175202.77 7 [Welcome] Number Input 1
175202.77 7 rv add [Welcome]{1}
175202.77 7 TimeoutClear
175202.77 7 [Messages Menu] Playing
175202.77 7 [Messages Menu] Playing (messages menu.wav)
175202.78 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\VPQMCOSYS\messages menu.wav]
175202.78 7 TimeoutClear
175202.78 7 RunModule PLAY end
175202.78 7 wa(20542,79443700)
175202.78 7 callinfo MONITORMODES
175207.38 7 dtmf 2 (65980,50,2)
175207.38 7 ScriptEventCode 50 iLineState=1100
175207.38 7 LsPlayMsg 2
175207.38 7 voicemail used: Scripted
175207.38 7 stack idx=1
175207.38 7 rv add [scriptStart_Time]{14/05/2004 17:52:07}
175207.38 7 rv add [scriptStart_CalledFrom_Script]{C:\Program Files\VoiceGuide\Scripts\VPQMCOSYS\vpqmcosys.vgs}
175207.38 7 rv add [scriptStart_CalledFrom_Module]{Messages Menu}
175207.38 0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLm.vgs at idx=2
175207.38 7 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\system\vm\}
175207.38 7 rv add [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}
175207.38 7 rv add [PathDataVm]{C:\Program Files\VoiceGuide\data\}
175207.38 7 rv add [PathVgSys]{C:\Program Files\VoiceGuide\system\}
175207.38 7 rv add [vmbId]{0003}
175207.44 7 PlaySoundStop err=0
175207.44 7 rv add [VmLmStart]{2}
175207.44 7 TimeoutClear
175207.44 7 [VmLmStart] Running vb script:[VmLmHangup.vgs]
175216.78 0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLmHangup.vgs at idx=3
175216.78 7 TimeoutClear
175216.78 7 [VmLmHangup_ForwardLastMsg] Running VB Script...
175216.78 7 RVreplace start (strlen>500)
175216.78 7 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\VPQMCOSYS\}[$RV_STARTTIME]{14/05/2004 17:51:56}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{412748488}[Welcome]{1}[scriptStart_Time]{14/05/2004 17:52:07}[scriptStart_CalledFrom_Script]{C:\Program Files\VoiceGuide\Scripts\VPQMCOSYS\vpqmcosys.vgs}[scriptStart_CalledFrom_Module]{Messages Menu}[scriptsPath]{C:\Program Files\VoiceGuide\system\vm\}[PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[vmbId]{0003}[VmLmStart]{2}[Key_VmLmStopRecAndPlay]{1}[Key_VmLmDelRecRecAg
in]{2}[Key_VmLmSaveAndPlayGreeting]{3}[Key_VmLmDeleteGoGroupPrevious]{4}[Key_VmL
DeleteAndPlayGreeting]{5}[Key_VmLmDeleteGoGroupNext]{6}[Key_VmLmSaveGoVmLogin]{8
[Key_VmLmSaveVmExit]{0}[Key_VmLmSaveGoLmRecMsgMenu]{#}[RecMessage]{}[VmbWelcMsg]
C:\Program Files\VoiceGuide\data\VmWelc\0003.wav}[VmLmRecFilename]{0003_0514175210_1_7_412748488_.wav}[MsgLenMax]{3
0}[VmLmRec]{C:\Program Files\VoiceGuide\data\VmSave\0003_0514175210_1_7_412748488_.wav}[VmLmRec_RecLen100ms]{55}[VmLmRec_EndRec
ause]{disconnect}[Hangup Time]{14/05/2004 17:52:16}
175216.80 7 eng copy of script ran: vbs_7_3.vbs
175216.80 7 Run Script waiting... (shellid=1148, process=1708)
175216.81 7 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
175216.81 7 tapi Reply (LineEvReply) ok 65997 0
175216.81 0 cl Vm_VmbConfig_Get 0003, MsgLenMin
175216.83 7 vm RecLen100ms=55, MinLength for VMB0003=0
175216.83 7 cl Vm_Event 7, FORWARD, 0003, C:\Program Files\VoiceGuide\data\VmSave\0003_0514175210_1_7_412748488_.wav, ,
175216.83 7 vm frwrd vmb 0003
175216.83 7 rv add [VoicemailMessage0003]{C:\Program Files\VoiceGuide\data\VmSave\0003_0514175210_1_7_412748488_.wav}
175216.83 7 AddRVns [VoicemailMessage]{C:\Program Files\VoiceGuide\data\VmSave\0003_0514175210_1_7_412748488_.wav}
175216.83 7 RVreplace start: [cmd.exe /c copy "$RV[VoicemailMessage0003]" "c:\Anthony's Messages"]
175216.83 7 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\VPQMCOSYS\}[$RV_STARTTIME]{14/05/2004 17:51:56}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{412748488}[Welcome]{1}[scriptStart_Time]{14/05/2004 17:52:07}[scriptStart_CalledFrom_Script]{C:\Program Files\VoiceGuide\Scripts\VPQMCOSYS\vpqmcosys.vgs}[scriptStart_CalledFrom_Module]{Messages Menu}[scriptsPath]{C:\Program Files\VoiceGuide\system\vm\}[PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[vmbId]{0003}[VmLmStart]{2}[Key_VmLmStopRecAndPlay]{1}[Key_VmLmDelRecRecAg
ause]{disconnect}[Hangup Time]{14/05/2004 17:52:16}[VoicemailMessage0003]{C:\Program Files\VoiceGuide\data\VmSave\0003_0514175210_1_7_412748488_.wav}[VoicemailMessage]{C:\Program Files\VoiceGuide\data\VmSave\0003_0514175210_1_7_412748488_.wav}
175216.83 7 Run (VMB specific):cmd.exe /c copy "C:\Program Files\VoiceGuide\data\VmSave\0003_0514175210_1_7_412748488_.wav" "c:\Anthony's Messages"
175216.83 7 vm frwrd vmb 0003 end
175216.83 7 cl Vm_Event 7, MSG_NEW, 0003, , ,
175216.86 7 VBScript started [wscript "C:\Program Files\VoiceGuide\data\vbs_7_vm_msglamp_on_040514175216.vbs" //I //T:3600]
175216.86 7 vm msglamp_on ok
175216.88 7 cl Run_ResultReturn >>success<<
175216.88 7 rv add [VmLmHangup_ForwardLastMsg_ResultReturn]{success}
175216.88 7 path {success} not found
175216.88 7 rv add [Hangup Time]{14/05/2004 17:52:16}
175216.88 7 Hanging up call... [Run_ResultReturn - no path match (diff vgm)]
175216.88 7 HangupCall_Common Mode=AfterHangupRun
175216.88 7 ReinitTelephony due to IDLE
175216.89 7 tapic lineDeallocateCall(MainCall:65980) 0
175217.06 7 lineOpen(7)=>
175217.06 7 Waiting for a call...
175217.06 7 LineHandle=66014
175217.06 7 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
175220.23 7 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
175220.23 7 ScriptEventCode 9013 iLineState=900
vpqmcosys.zip
hi also noticed not all call recordings are being truncated properly,
on some call recordings the tone recorded after the caller has hungup is sometimes recorded longer (4-5 seconds), on other calls the recording ends with a short beep which is the ideal situation.
your assistance would be appreciated
rgds
I'd say that as VoiceGuide was working rock solid for the last year and you have not changed anything on the PC running VG then the problem most likely lies with the PBX.
Can you please provide a trace of a situation that you describe as: "occassionally calls will not be released on 1 line" - are you saying the VG does not hangup the line after call is finised? We should be able to see pretty quickly in the trace just what is going on there...
As for the "the call is sometimes answered by vg." - can you see the PBX ringing the extension plugged into the Dialogic card? - you should be able to see this in the trace as well. VG is pretty reliable with answering on the correct ring - so if you are not getting your call answered I'd say it's because the PBX has not routed it to the correct extension....
The attached trace shows a successful call and all appears fine...
Please post the recording and the trace which captured the call during which that recording was made.
when next on site I will obtain trace & recording of a call that is not truncated properly, on average 4 out of say 80 calls per night are recorded for approx 5 mins, it seems end of call is not being detected ?, the caller hangs up but vg keeps recording the disconnect/busy tone until it times out, I have set the max record time in voice manager at 4/5 min limit.
