Guest alberto molinero Report post Posted 05/14/2004 09:32 AM Hello! i am from spain and i´m looking for a ivr solution for our customer. Actually we use to handle Verbio tts (local provider) in our installations. This sw support SAPI 5. Is it possible (and easy) use this tts with voice guide? Do you have any comercial support in europe? Thanks in advance! Alberto Molinero Share this post Link to post
SupportTeam Report post Posted 05/15/2004 07:18 AM If the TTS engine supports SAPI5 then you should be able to use it with VoiceGuide straight away. Share this post Link to post
Guest Guest Report post Posted 05/17/2004 05:23 PM Where can i find an example of tts use? In the demo i have downloaded, i can´t find a node for tts... Thanks in advance Share this post Link to post
SupportTeam Report post Posted 05/18/2004 03:04 AM You can use TTS wherever there is an option to play a sound file - just specify a text file and that text file will be spoken. Also see the Play module: http://www.voiceguide.com/vghelp/html/modPlay.htm Share this post Link to post
