Zoom 3049c External .inf
I palyed around today trying to get an .INF file working properly on my 3049C, but no joy :(
Has anyone here got an Inf file that works with VG for this modem?
I had to alter the supplied file even to get the Caller ID to work properly.
thanks,
phew (UK)
If this modem uses a Rockwell chipset then you could try installing it as a Rockwell voice modem - see the options available to you under the Rockwell set of drivers in Windows.
Another driver that usually works is the Olitec modem driver.
So I guess this modem does not always work with VG then?
I came accross another comms/phone software that does the recording, but not all that VG seems capable of.
It claims TAPI compliance..and works with my XP/UK install...Van anyone help?
It all depends on the drivers - if you install the right drivers for the modem then it should work...
You may also want to see v2.9.1 of VG. Version 2.9.1 of VoiceGuide communicates directly with the modem without the use of Wave drivers - which may be desirable by some users. (Many other voice programs still communicate with the modem directly rather then use Wave drivers). You can download VoiceGuide v2.9.1 from: http://www.voiceguide.com/vgDownload.htm
