Guest cangracom Report post Posted 05/17/2004 07:07 PM I've downloaded and installed v5.2.2. Voiceguide still seems to be using my network card as the unique identifier. I'd like to use the diallogic card as the identifier. How can I go about doing that.? As well, when I start up voiceguide, I get the following message: This version of VoiceGuide can only run scripts up to 30 modules in size. Remainder of the script was not loaded. I'm not sure if that message is tied to the fact that my installation is not registered yet. And I can't register it until I can select my diallogic card as the system identifier. Any help you could give on this matter would be appreciated. Jamie Share this post Link to post
SupportTeam Report post Posted 05/18/2004 03:06 AM Is the Dialogic service showing as started in the DCM? Can you post a screenshot of the VG Registration screen together with Dialogic DCM screen? This version of VoiceGuide can only run scripts up to 30 modules in size. The evaluation version of VG has this limit. Share this post Link to post
