Command Line Parameters
Kindly note that with the new release of Voice Guide 5.2.2000 the -hide command parameter is not working !!
Any ideas on what to do ?? I don't want the user to see what are the numbers that are being entered through the phone.
Thanx,
Musaed :)
Are you using a Dialogic card or a modem?
If a Dialogic card then which card are you using
Hi :)
I'm using Creative PCI Modem. Would that make any difference ? The -hide option was working great on the VG4.9 and VG5.0a (I think I can't remember exact version but not the 5.2.2000) release.
Please place the relevant OCX in your Windows' System 32 directory, and then place .exe attached in next message in your VoiceGuide directory.
"-hide" should then work OK.
TapiWrap_1.84.zip
I have a registered version of VG would those 2 files make any problems 2 me after overwriting the old files ?
Your registration would remain unchanged.
(Registration info is stored in USERINFO.INI file)
(if you want just make backup copies of the files you are overwriting...)
I @-@, I did make a backup of the files before the copy. I tested the -hide command and its working fine.
Many thanx :)
Musaed
