mkusa Report post Posted 05/19/2004 10:12 AM Kindly note that with the new release of Voice Guide 5.2.2000 the -hide command parameter is not working !! Any ideas on what to do ?? I don't want the user to see what are the numbers that are being entered through the phone. Thanx, Musaed Share this post Link to post
SupportTeam Report post Posted 05/19/2004 09:52 PM Are you using a Dialogic card or a modem? If a Dialogic card then which card are you using Share this post Link to post
mkusa Report post Posted 05/20/2004 04:44 AM Hi I'm using Creative PCI Modem. Would that make any difference ? The -hide option was working great on the VG4.9 and VG5.0a (I think I can't remember exact version but not the 5.2.2000) release. Share this post Link to post
SupportTeam Report post Posted 05/20/2004 05:00 AM Please place the relevant OCX in your Windows' System 32 directory, and then place .exe attached in next message in your VoiceGuide directory. "-hide" should then work OK. TapiWrap_1.84.zip Share this post Link to post
SupportTeam Report post Posted 05/20/2004 05:01 AM VgMulti.exe v5.2.2009 VgMulti_5.2.2009.zip Share this post Link to post
mkusa Report post Posted 05/20/2004 05:19 AM I have a registered version of VG would those 2 files make any problems 2 me after overwriting the old files ? Share this post Link to post
SupportTeam Report post Posted 05/20/2004 06:18 AM Your registration would remain unchanged. (Registration info is stored in USERINFO.INI file) (if you want just make backup copies of the files you are overwriting...) Share this post Link to post
mkusa Report post Posted 05/20/2004 07:23 AM I @-@, I did make a backup of the files before the copy. I tested the -hide command and its working fine. Many thanx Musaed Share this post Link to post
