Setup And Test Demo Problem
I'm at the very beginning trying to evaluate VoiceGuide for our company. I've got the VoiceGuide installed. The card is a Dialogic D/4PCI. I have successfully set up the Dialogic TAPI services, and they are recognized by the VoiceGuide main window. Also The WaveGuide driver seems to be correctly installed. I'm running W2K Prof on a new machine. I've downloaded and installed the mu-law files that this card wants.
We've got a Executone/Isoetec System 228 with a four port IVR system, hooked to the 4 ports of the Dialogic card. For testing, I've turned off sending DTMF tones when a phone dials into the VoiceGuide application.
I'm trying to run the demo Credit Card application. The phone dials in, waits for a few rings, and is then hung up by Voice Guide. Here is the log:
66319 7 tapie linedevstate 2048 0 0
66319 7 tapie callstate OFFERING 65964 0 4
66329 7 tapie callinfo CALLEDID
66329 7 tapie callinfo ORIGIN
66339 7 tapie ring 0
72337 7 tapie ring 2
72337 7 Answer the call
72337 7 lineAnswer(65964) => 66135
72878 7 tapie callstate CONNECTED 65964,1,0
72878 7 WorkingModeTAPI=
72878 7 WorkingModeScript=
72928 7 tapi Reply 66135 0
72928 7 tapie callinfo MONITORMODES
72928 7 TimeoutClear
72938 7 [Get Client ID] Number Input
72938 7 [Get Client ID] Playing (PayGetId.wav)
72958 7 Play Start line[7] err=[0 wavec waveOutOpen(0x0, 0x0, 0x217150, 0x0, 0x0, 0x5) => 32 (WAVERR_BADFORMAT) - format query with wave mapped] file[C:\Katalina\VoiceGuide\Scripts\Credit Card Payment\PayGetId.wav]
72968 7 PlaySoundStart line[7] err=[0 wavec waveOutOpen(0x0, 0x0, 0x217150, 0x0, 0x0, 0x5) => 32 (WAVERR_BADFORMAT) - format query with wave mapped] [C:\Katalina\VoiceGuide\system\voicedlgc\ErrorPlayingFile.wav]
72978 7 For Dialogic use: PCM 11Khz 8bit Mono
72978 7 Hanging up call...
72988 7 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
72988 7 PlaySoundStop ok
72998 7 fnHangupCall end
72998 7 tapie callinfo MONITORMODES
74911 7 tapie linedevstate 2048 0 0
74911 7 tapie callstate IDLE 65964 0 0
74911 7 WorkingMode@Idle=
74921 7 TimeoutClear
74931 7 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
74931 7 tapi Reply 66186 0
75832 7 Timer fired EV_TIMEOUT_TIMETOREINITLINE
75832 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
75842 7 Initialise telephony (due to IDLE)
75842 7 tapic lineDeallocateCall(MainCall:65964) 0
75993 7 Waiting for a call...
75993 7 hLine=65725
75993 7 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT
81100 7 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT
Please help. The software looks great, but I certainly haven't gotten very far!
Jeff Bush
D/4PCI does not require MuLaw sound files - it uses PCM 11025Hz 8bit Mono.
You'll need to download the correct format and update your sound files.
(Please see http://www.katalinatech.com/suppRecomHardware.htm )
That’s why you are getting the WAVERR_BADFORMAT error message...
Are you using the latest version of VoiceGuide?
Are you using Dialogic's System Release drivers v5.01 or later?
I downloaded and installed the .wav files you suggest. However, they seem to yield the same error indication as before. The event log is at the end of this post. I examined the files closely to make sure that I had downloaded the correct ones from your site. They are in fact 11K, 8bit Mono files, from your site.
VoiceGuide version is 4.8.45
The Dialogic Config Manager reports the following:
OS: W2K SP3
Dialogic Release SR5.1 Ver.DNA5 Build26
Windows Device Manager reports that no drivers have been installed for this device, but all Dialogic functions appear to work. Service Starts and Stops. 4 Ports appear in the VoiceGuide status area, "Waiting For Call". Etc. I have not run the entire Universal Dialogic Diagnostics.
Here's the Event Log:
35258 5 tapie linedevstate 2048 0 0
35258 5 tapie callstate OFFERING 65999 0 4
35278 5 tapie callinfo CALLEDID
35278 5 tapie callinfo ORIGIN
35278 5 tapie ring 0
41277 5 tapie ring 2
41277 5 Answer the call
41277 5 lineAnswer(65999) => 66238
41818 5 tapie callstate CONNECTED 65999,1,0
41818 5 WorkingModeTAPI=
41818 5 WorkingModeScript=
41878 5 tapi Reply 66238 0
41878 5 tapie callinfo MONITORMODES
41878 5 TimeoutClear
41878 5 [Get Client ID] Number Input
41878 5 [Get Client ID] Playing (PayGetId.wav)
41908 5 Play Start line[5] err=[0 wavec waveOutOpen(0x0, 0x0, 0x20ab60, 0x0, 0x0, 0x5) => 32 (WAVERR_BADFORMAT) - format query with wave mapped] file[C:\Katalina\VoiceGuide\Scripts\Credit Card Payment\PayGetId.wav]
41918 5 PlaySoundStart line[5] err=[0 wavec waveOutOpen(0x0, 0x0, 0x20ab60, 0x0, 0x0, 0x5) => 32 (WAVERR_BADFORMAT) - format query with wave mapped] [C:\Katalina\VoiceGuide\system\voicedlgc\ErrorPlayingFile.wav]
41918 5 For Dialogic use: PCM 11Khz 8bit Mono
41918 5 Hanging up call...
41928 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
41928 5 PlaySoundStop ok
41938 5 fnHangupCall end
41938 5 tapie callinfo MONITORMODES
41948 5 tapie callinfo MONITORMODES
43851 5 Timer fired EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
43851 5 Hanging up call...(2)
43861 5 PlaySoundStop ok
43861 5 fnHangupCall end
43871 5 LsAwaitingCalls EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
43871 5 tapi Reply 66460 LINEERR_OPERATIONFAILED [80000048]
43881 5 tapie linedevstate 2048 0 0
43881 5 tapie callstate IDLE 65999 0 0
43891 5 WorkingMode@Idle=
43891 5 TimeoutClear
43901 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
43901 5 tapi Reply 66529 0
44872 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
44872 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
44872 5 Initialise telephony (due to IDLE)
44882 5 tapic lineDeallocateCall(MainCall:65999) 0
45032 5 Waiting for a call...
45032 5 hLine=66409
45032 5 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT
50049 5 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT
Please help further. The product appears useful, but I'm not having much success.
Jeff Bush
Please post the "PayGetId.wav" file that is giving you problems.
Can you try playing any of the sound files from VoiceGuide's system/voicedlgc directory?
Tried playing the files in the system/voicedlgc directory. They all play fine (in Windows Media Player).
I received this error when attempting to attach "PayGetId.wav".
THE FOLLOWING ERROR(S) WERE FOUND
You cannot upload this type of file
However, the file plays fine in Windows Media Player.
Thanks for whatever help you can give.
Jeff
Please send the file to support@katalinatech.com
Can you try playing any of the sound files from VoiceGuide's system/voicedlgc directory in VoiceGuide - just edit the script to use those files instead of "PayGetId.wav"
Hello
I am facing exactly the same problem as Jeff. Tried/checked all the suggestiions u have provided here.
Still my problem persists
Event Log:
15515 6 [Get Client ID] Number Input
15515 6 [Get Client ID] Playing (PayGetId.wav)
15515 6 Play Start line[6] err=[0 wavec waveOutOpen(0x0, 0x0, 0x2a45240, 0x0, 0x0, 0x5) => 32 (WAVERR_BADFORMAT) - format query with wave mapped] file[PayGetId.wav]
I have attached PayGetId.wav for ur ref. It is in PCM 11.025 kHz, 8 Bit, Mono format, but as u can see it is not accepted by ur software.
Pls clarify on priority.Awaiting a solution
Regds
Sudhi
Sounds like the cards Wave drivers were not correctly installed - can you
try removing all the wave drives on your system (including any sound card drivers) and then re-installing the wave drivers for your telephony device first. Try calling in after doing this, and if the sound can be heard over the phone you can then try to re-install your sound card drivers.
