SupportTeam Report post Posted 05/27/2004 05:20 AM Ted (Manuel) Valdez wrote: Hi there. I registered the 4 line version of VGPro and love it. I have a question however. I am running an outgoing call campaign. It currently saves the $RV_CALLEDNUMBER variable using the Command Prompt DOS echo command if the user want to be removed from further calls which saves to the DoNotCall list This is the same DNC list that Dialer uses too. It is saving the phone number with a 1 in front of it, since that is the prefix to dial out. However, the numbers I load into Dialer do not have the one in front so it does not reject numbers properly. command.com /c echo $RV_CALLEDNUMBER >> c:\DNC-List.txt Can you please tell me how I can save the $RV_CALLEDNUMBER without the 1 in front? Much thanks in advance, Ted (Manuel) Valdez Share this post Link to post
SupportTeam Report post Posted 05/27/2004 05:35 AM You can use the Evaluate Expression module to extract just the part of the number you want from $RV_CALLEDNUMBER, save it in another Result Variable and then append that new RV to the text file. Use the mid() function to extract the number. eg. to extract 10 digits starting from the second digit onwards you would specify an expression like this in the Evaluate Expression module: mid($RV_CALLEDNUMBER, 2, 10) more information on mid() and other functions which can be used in the Evaluate Expression module can be found at http://www.voiceguide.com/vghelp/html/modEvalExpr.htm Share this post Link to post
SupportTeam Report post Posted 05/27/2004 08:06 AM Ted (Manuel) Valdez wrote: thank you Thank You THANK YOU! Share this post Link to post
