How Do I Remove The 1 In Front Of A Phone Number?
Ted (Manuel) Valdez wrote:
Hi there.
I registered the 4 line version of VGPro and love it. I have a question
however.
I am running an outgoing call campaign. It currently saves the
$RV_CALLEDNUMBER variable using the Command Prompt DOS echo command if the
user want to be removed from further calls which saves to the DoNotCall list
This is the same DNC list that Dialer uses too. It is saving the phone
number with a 1 in front of it, since that is the prefix to dial out.
However, the numbers I load into Dialer do not have the one in front so it
does not reject numbers properly.
command.com /c echo $RV_CALLEDNUMBER >> c:\DNC-List.txt
Can you please tell me how I can save the $RV_CALLEDNUMBER without the 1 in
front?
Much thanks in advance,
Ted (Manuel) Valdez
You can use the Evaluate Expression module to extract just the part of the number you want from $RV_CALLEDNUMBER, save it in another Result Variable and then append that new RV to the text file.
Use the mid() function to extract the number. eg. to extract 10 digits starting from the second digit onwards you would specify an expression like this in the Evaluate Expression module:
mid($RV_CALLEDNUMBER, 2, 10)
more information on mid() and other functions which can be used in the Evaluate Expression module can be found at http://www.voiceguide.com/vghelp/html/modEvalExpr.htm
