Problems With Hang Up
Hi guys,
I have this problem:
I'm using vg 5.2.2 on a XP pro. system and a voice modem (SoftK56 Data Fax voice CARP) that works well.
My only problem is that I'm using VG for oubound calls and when script starts, a voice message is "speaked" for 2 times.
If the person who answer the call, press something or waith on line until the end of the message, there are no problems, but, if the person hang up call before the end of the message, script, when has finished to play for 2 times the audio file, stops.
I want that vg, in this case, goes on a VBS module to made a DB update, like it does in "timeout" case...how can I solve this problem, if can I....
I send you my script, so in some way you can understand better what is my problem.
Tnx a lot for your help.
scriptVoice.vgs
Trace shows that after outgoing call was accepted the file Benvenuto.wav was played twice:
114210,63 0 [benvenuto] Playing (Wave\Benvenuto.wav)
114255,15 0 [benvenuto] Playing (Wave\Benvenuto.wav)
and then modem detected that recipent of the call hung up:
114341,57 0 callstate DISCONNECTED 66458,1,0
and the line was then reset ready for another call.
All seems OK from the trace...can you tell us where the problem occurs?
The problem is that if the person hang up the call, VG doesn't made the update in the database because it "disconnect".
I need VG made this update...it's essential.
How can I do?
TNX
If you want the module "SalvaRisp" to always execute when the call is finished you should put it in an "OnHangup" script. Please see: http://www.voiceguide.com/vghelp/html/Call...ll%20Finish.htm
and you may want to use:
set Conn=Nothing
towards the end of the VB Script in the module "SalvaRisp" - else memory assigned in your VBSCript to the Conn object may not be freed...
