Vermut Report post Posted 04/02/2003 09:28 AM I'm trying to use Microsoft H.323 Telephony service provider with VG. I enter gatekeeper and stuff, select H323 Line from VG Configurator and start VG. On H.323 Properties page it says Registered, and on gatekeeper i see registration, but when I try to call the system, it simply ignores SETUP message. What do i do wrong? I use plain new installation, without any alterations. Script was used is Voicemail script. Share this post Link to post
SupportTeam Report post Posted 04/02/2003 02:29 PM H323 is not supported by VoiceGuide at this stage... Share this post Link to post
Vermut Report post Posted 04/02/2003 02:37 PM Maybe you know, what software supports it? Share this post Link to post
SupportTeam Report post Posted 04/02/2003 10:15 PM If you want an IVR systems which supports IP Telephony then I'd suggest looking at packages like Envox... Do you want to set up an IP based voicemail system or do you have another application in mind? Supporting IP calls has been discussed for inclusion in VoiceGuide, but there are a few other features that are slotted for addition first... Share this post Link to post
