Using Tapi H.323 Provider
I'm trying to use Microsoft H.323 Telephony service provider with VG. I enter gatekeeper and stuff, select H323 Line from VG Configurator and start VG.
On H.323 Properties page it says Registered, and on gatekeeper i see registration, but when I try to call the system, it simply ignores SETUP message. What do i do wrong?
I use plain new installation, without any alterations. Script was used is Voicemail script.
If you want an IVR systems which supports IP Telephony then I'd suggest looking at packages like Envox...
Do you want to set up an IP based voicemail system or do you have another application in mind?
Supporting IP calls has been discussed for inclusion in VoiceGuide, but there are a few other features that are slotted for addition first...
