Tts 'please Check The File Format...'
I have an issue which is the same as the one titled:
Tts "...please Check The File Format" , using AVM Fritz!Card with ComISDN
i think the link is
http://voiceguide.com/forums/index.php?sho...tisopenandready
I get this same error intermittently also. The file will run fine the first time but the second time I wil get the msg "THe sound file specified...". Have you guys found out any other information on this issue. My system is Win2k Advanced Server with SQL Server 2000.
My system does not hang always after this happens, only sometimes. This time it did not hang.
THe log is below begining after it has played correctly the first time:
234459.20 5 db [GetVerifyPrompt] row count=1
234459.20 5 rv add [GetVerifyPrompt_RowCount]{1}
234459.22 5 db get RecordsetGetRowsMax
234459.22 5 db get 999 records. (row count=1)
234459.23 5 db update RVs
234459.23 5 db about to close dbDbqDatabase
234459.25 5 db going down path [True]
234459.27 5 TimeoutClear
234459.27 5 [VerifySettings] Number Input
234459.28 5 RVreplace start: [$RV[GetVerifyPrompt_1_1]]
234459.30 5 RVreplace end: [C:\Prepaid\VoiceGuide\English\Eng_VerifyEntries.txt]
234459.30 5 RVreplace start (strlen>500)
234459.33 5 tts generate start[<?xml version="1.0" encoding="ISO-8859-1"?> These are your current basic settings. IF there is a pause for the entry value, that means there is no value. Outside Line or PBX Value: <spell>44</spell><silence msec='1000'/> If these are correct, press 1. Press 2 to return to the Main Menu. ]
234459.36 5 tts generate wait
234459.88 5 tts generate finish
234459.89 5 RVreplace start: [$RV[GetVerifyPrompt_1_1]]
234459.91 5 RVreplace end: [C:\Prepaid\VoiceGuide\English\Eng_VerifyEntries.txt]
234459.91 5 [VerifySettings] Playing (C:\Program Files\VoiceGuide\data\tts5.wav)
234500.03 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts5.wav]
234500.03 5 TimeoutClear
234500.05 5 wa(30375,77471800)
234500.06 5 callinfo MONITORMODES
234530.45 5 wb(77471800)
234530.59 5 Play End line[5] (id=774718)
234530.59 5 ScriptEventCode 8001 iLineState=1300
234530.61 5 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
234530.61 5 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
234535.97 5 Timer fired EV_TIMEOUT_REPLAYMSG
234535.97 5 ScriptEventCode 9005 iLineState=1301
234535.97 5 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
234535.98 5 RVreplace start: [$RV[GetVerifyPrompt_1_1]]
234536.00 5 RVreplace end: [C:\Prepaid\VoiceGuide\English\Eng_VerifyEntries.txt]
234536.00 5 tts generate reuse
234536.02 5 [VerifySettings] Playing ($RV[GetVerifyPrompt_1_1], C:\Program Files\VoiceGuide\data\tts5.wav)
234536.05 5 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>2,play pss EnsureWaveOutIsOpenAndReady=>play FileMmioOpenAndAscend failed in Play_EnsureWaveOutIsOpenAndReady] [C:\Prepaid\VoiceGuide\English\Eng_VerifyEntries.txt,C:\Program Files\VoiceGuide\data\tts5.wav]
234536.20 5 TimeoutClear
234536.22 5 tapie PlayEnd old line=5 0 810812
234536.23 5 wa(4425,81081200)
234536.25 5 callinfo MONITORMODES
234540.73 5 wb(81081200)
234540.77 5 Play End line[5] (id=810812)
234540.77 5 ScriptEventCode 8001 iLineState=1300
234540.77 5 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
234540.78 5 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
234541.05 0 btn Hangup on line 5
234541.06 5 ScriptEventCode 9001 iLineState=1301
234541.06 5 LsGetNbrsRxDigits EV_TIMEOUT_HANGUP
234541.06 5 rv add [Hangup Time]{6/6/2004 11:45:41 PM}
234541.08 5 Hanging up call...
234541.09 5 RecSoundStop ok
234541.11 5 PlaySoundStop err=0
234541.13 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
234541.16 5 fnHangupCall end
234541.20 5 linedevstate 2048 0 0
234541.22 5 callstate IDLE 65800 0 0
234541.22 5 WorkingMode@Idle=
234541.23 5 TimeoutClear
234541.25 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
234541.27 5 tapi Reply (LineEvReply) ok 65817 0
234542.27 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
234542.27 5 ScriptEventCode 9008 iLineState=900
234542.27 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
234542.28 5 ReinitTelephony due to IDLE
234542.28 5 tapic lineDeallocateCall(MainCall:65800) 0
234542.45 5 lineOpen(5)=>
234542.47 5 Waiting for a call...
234542.47 5 LineHandle=65663
234542.48 5 TimeoutSet 30 EV_TIMEOUT_ATERIDLE_ALLOWOUT
I found another post regarding the same issue I have, is the file named VgMulti_5.2.1010.zip the latest one available. If not, please let me know what is.
I am running version 5.2.1201.
Please update to VoiceGuide v5.2.2 (uninstall v5.2.1 first and then install v5.2.2).
I think the problem you are seeing was fixed in v5.2.2
