Guest david Report post Posted 06/07/2004 01:56 PM URGENT I have win 2000 sp4 voiceguide 5.2.2011 professional edition 2 line my problem is the transfert appel 0607vgm.txt Share this post Link to post
Guest david Report post Posted 06/07/2004 01:58 PM I have a matra 6500 as pbx Share this post Link to post
SupportTeam Report post Posted 06/07/2004 10:24 PM What is the actual problem? If the problem is to do with the hookflash length then I'd advise reading: http://www.voiceguide.com/vghelp/html/Dial...llTransfers.htm Share this post Link to post
Guest david Report post Posted 06/08/2004 01:48 PM i'm french sorry for my english what is the hookflash length for a pbx matra 6530 ? i have tested many solution in the menu of voiceguide pbx command strings i have this message voiceguide has detected that the above settings are NOT used by Voiceguide to perform call transfers.Current setting is: TAPI/TAPI IT s normal ? Share this post Link to post
SupportTeam Report post Posted 06/09/2004 01:31 AM Are you using a modem or a Dialogic card? Regarding the message in red, please see the VG.INI file, entries: TransferControl_Modem TransferControl_TelBoards Share this post Link to post
Guest david Report post Posted 06/09/2004 08:57 AM yes i have a d4pci dialogic cards in the vg.ini TransferControl_Modem=TAPI TransferControl_TelBoards=TAPI thanks to help me Share this post Link to post
SupportTeam Report post Posted 06/09/2004 09:23 AM I'd recommend trying setting TransferControl_TelBoards=Generate and restarting VoiceGuide. What is the actual problem? At what stage of attempting the transfer does the transfer fail? Share this post Link to post
Guest david Report post Posted 06/09/2004 10:32 AM change the vg.ini and the menu of voiceguide pbx command strings i have this message voiceguide has detected that the above settings are NOT used by Voiceguide to perform call transfers.Current setting is: TAPI/Generate when i make a transfer voiceguide hangup after to have composed the number of poste Share this post Link to post
SupportTeam Report post Posted 06/09/2004 10:34 AM when i make a transfer voiceguide hangup after to have composed the number of poste When does it hangup? If it hangs up at about the time when the hookflash is played then it looks like the hookflash is set too long. Please read: http://www.voiceguide.com/vghelp/html/Dial...llTransfers.htm Share this post Link to post
