Guest Guest Report post Posted 06/09/2004 02:56 PM Hi all, I'm using VG 5.2.2, with a Dialogic D4PCIU on a win XP pro SP1 and I've this problem (I've posted you my VG script and the call log so you can understan as well): I made a call to the VG phone number and all works well until script runs "Istruzioni lettura" module. The first time there are no problems, if I press 1 or 2 on my phone, module stops plaiyng audio file and the next path is runned, and, as you can see, if the first time I press 1, after all process, script returns to the "Istruzioni lettura". Here is the problem: VG starts playing the wav specified in "Istruzioni lettura", but if I press 2, the script goes to the "SpiegaInserLettura" module, but VG continue plaiyng the same wave file so I can heard only the "beep" generated from "GetLettura" module. I hope I'm clear on my explanation. Let me know if there is a solution. Many thanx. Post.zip Share this post Link to post
SupportTeam Report post Posted 06/10/2004 12:53 AM Trace shows everything is OK, with [spiegaInserLettura] correctly starting play: 163320,23 6 [spiegaInserLettura] Playing (Wave\Wave script\SpiegaInserLettura.wav) 163320,27 6 PlaySoundStart ok [C:\Programmi\VoiceGuide\RioTorto\Wave\Wave script\SpiegaInserLettura.wav] immediately after DTMF 2 was pressed: 163320,20 6 dtmf 2 (66474,50,2) Please select 'save to log files' and then reproduce the problems and post the extracts from the log file "MMDDtw.txt" as well as the log file "MMDDvgm.txt" which capture the problem - the "MMDDtw.txt" file should give us more info. 163315,45 6 [istruzioni lettura] Playing 163315,45 6 [istruzioni lettura] Playing (Wave\Wave script\IstruzioniGen.wav) 163315,47 6 PlaySoundStart ok [C:\Programmi\VoiceGuide\RioTorto\Wave\Wave script\IstruzioniGen.wav] 163315,47 6 TimeoutClear 163315,48 6 RunModule PLAY end 163315,48 6 wb(52429600) 163315,48 6 wa(12934,52501500) 163315,50 6 callinfo MONITORMODES 163320,20 6 dtmf 2 (66474,50,2) 163320,20 6 ScriptEventCode 50 iLineState=1100 163320,20 6 LsPlayMsg 2 163320,22 6 PlaySoundStop err=0 163320,22 6 rv add [istruzioni lettura]{2} 163320,23 6 TimeoutClear 163320,23 6 [spiegaInserLettura] Playing 163320,23 6 [spiegaInserLettura] Playing (Wave\Wave script\SpiegaInserLettura.wav) 163320,27 6 PlaySoundStart ok [C:\Programmi\VoiceGuide\RioTorto\Wave\Wave script\SpiegaInserLettura.wav] 163320,28 6 TimeoutClear 163320,28 6 RunModule PLAY end 163320,28 6 wa(8111,52981200) 163320,30 6 callinfo MONITORMODES 163328,42 6 wb(52981200) 163328,47 6 Play End line[6] (id=529812) 163328,47 6 ScriptEventCode 8001 iLineState=1100 163328,48 6 LsPlayMsg EV_PLAY_FINISHED 163328,48 6 TimeoutSet 10 EV_TIMEOUT_HANGUP 163328,50 6 TimeoutSet 1 EV_TIMEOUT_GOTOMODULE 163329,48 6 Timer fired EV_TIMEOUT_GOTOMODULE 163329,48 6 ScriptEventCode 9002 iLineState=1101 163329,48 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 163329,50 6 TimeoutClear 163329,50 6 [GetLettura] Number Input 163329,50 6 [GetLettura] Playing (C:\Programmi\VoiceGuide\system\voice\beep1.wav) 163329,53 6 PlaySoundStart ok [C:\Programmi\VoiceGuide\system\voice\beep1.wav] 163329,53 6 TimeoutClear 163329,53 6 wa(186,53907800) 163329,55 6 callinfo MONITORMODES 163329,73 6 wb(53907800) 163329,80 6 Play End line[6] (id=539078) Share this post Link to post
