Onnotconnected
I am running ver: 5.2.2000 evaluation.
I submit the following XML file:
<OutDialEntry>
<PhoneNumber>19724756676</PhoneNumber>
<CallTime>Now</CallTime>
<DayTimeStart>0001</DayTimeStart>
<DaysCallAllowed>MoTuWeThFrSaSu</DaysCallAllowed>
<AnnounceMessage></AnnounceMessage>
<OnAnswer>c:\data_x\hdhans1.vgs</OnAnswer>
<OnAnswerMachine>c:\data_x\hdham1.vgs</OnAnswerMachine>
<AnswerTimeout>20</AnswerTimeout>
<CallRetries>0</CallRetries>
<RetryDelay>0</RetryDelay>
<RV>57326</RV>
<OnNotConnected>c:\data_x\hdhno1.vgs</OnNotConnected>
</OutDialEntry>
It dials the number, I answer and the "OnAnswer" script runs. This is good.
I submit again, it dials, I do not answer, it times out and the "OnNotConnected" script does not run.
Here is the event log for the no answer run.
104613.67 0 Loading from C:\Program Files\VoiceGuide\data\OutDial_New.xml
104613.68 0 dial callque insert tel:19724756676 scr:c:\data_x\hdhans1.vgs time:406111046 esc:none
104613.72 0 Loaded 1 entries.
104614.74 5 dial [168,19724756676,406111046,1,2359,MoTuWeThFrSaSu,,,,0,,c:\data_x\hdhans1.vgs,c:\data_x\hdham1.vgs,57326,20,0,0,c:\data_x\hdhno1.vgs,none]
104614.76 0 dial callque update id=168 next call time 0406111048
104614.76 0 dial callque DB update returned
104614.77 5 dial found entry: tel[19724756676] ann[] vgs[c:\data_x\hdhans1.vgs] am[c:\data_x\hdham1.vgs]
104614.79 5 Dialing: 19724756676
104614.79 5 MakeCall => 65844
104614.79 5 TimeoutSet 20 EV_TIMEOUT_MAKECALL_NORESPONSE
104614.79 5 TapiCbTrigSet 65844 7002
104616.09 5 tapi Reply (LineEvReply) ok 65844 0
104616.09 5 TapiCbTrigClear
104616.09 5 linedevstate 2048 0 0
104616.09 5 callstate DIALTONE 65810 0 0
104616.10 5 callstate DIALING 65810 0 0
104616.10 5 callstate PROCEEDING 65810 0 0
104616.14 5 callinfo CALLEDID
104616.14 5 callinfo REASON
104616.17 5 Lev_CallerID [0000,]
104616.17 5 callinfo ORIGIN
104635.34 5 Timer fired EV_TIMEOUT_MAKECALL_NORESPONSE
104635.34 5 ScriptEventCode 9020 iLineState=5200
104635.34 5 LsWaitAfterDialingOut EV_TIMEOUT_MAKECALL_NORESPONSE
104635.35 0 dial callque delete id=168
104635.35 5 AddRVns [OutDial_Result]{Uncontactable_NoAnswer}
104635.35 5 dial no escalation info
104635.36 5 rv add [Hangup Time]{6/11/2004 10:46:35 AM}
104635.36 5 Hanging up call... [EV_TIMEOUT_MAKECALL_NORESPONSE]
104635.36 5 RecSoundStop ok
104635.36 5 PlaySoundStop err=0
104635.37 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
104635.39 5 Waiting for a call...
104635.39 5 fnHangupCall end
104635.51 5 linedevstate 2048 0 0
104635.51 5 callstate IDLE 65810 0 0
104635.51 5 WorkingMode@Idle=
104635.51 5 TimeoutClear
104635.51 5 LineState(iLineId).iVgsIdx = 0
104635.52 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
104635.52 5 tapi Reply (LineEvReply) ok 65827 0
104636.51 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
104636.51 5 ScriptEventCode 9008 iLineState=900
104636.51 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
104636.52 5 ReinitTelephony due to IDLE
104636.59 5 tapic lineDeallocateCall(MainCall:65810) 0
104637.71 5 lineOpen(5)=>
104637.71 5 Waiting for a call...
104637.71 5 LineHandle=65776
104637.71 5 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
104640.80 5 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
104640.80 5 ScriptEventCode 9013 iLineState=900
