Guest Harry Report post Posted 06/13/2004 04:53 PM See attached file. I used the following XML file to trigger an outdial. The phone rang and was answered. The log indicates an answer, but then something happens and it goes to Uncontactable_Error. What happened? <OutDialEntry> <PhoneNumber>19724756676</PhoneNumber> <CallTime>Now</CallTime> <DayTimeStart>0001</DayTimeStart> <DaysCallAllowed>MoTuWeThFrSaSu</DaysCallAllowed> <AnnounceMessage></AnnounceMessage> <OnAnswer>"c:\program Files\VoiceGuide\data\test.vgs"</OnAnswer> <OnAnswerMachine>"c:\program Files\VoiceGuide\data\ans_mach.vgs"</OnAnswerMachine> <AnswerTimeout>60</AnswerTimeout> <CallRetries>0</CallRetries> <RetryDelay>0</RetryDelay> <RV>[Cust_ID]{99999}</RV> <OnNotConnected>"c:\program Files\VoiceGuide\data\no_ans.vbs" "$RV[Cust_ID]" "$RV[OutDial_Result]" "$RV_CALLEDNUMBER" "$RV_LINEID" </OnNotConnected> </OutDialEntry> 125057.18 0 Loading from C:\Program Files\VoiceGuide\data\OutDial_New.xml 125057.20 0 dial callque insert tel:19724756676 scr:"c:\program Files\VoiceGuide\data\test.vgs" time:406131250 esc:none 125057.20 0 Loaded 1 entries. 125058.21 5 dial [250,19724756676,406131250,1,2359,MoTuWeThFrSaSu,,,,0,,"c:\program Files\VoiceGuide\data\test.vgs","c:\program Files\VoiceGuide\data\ans_mach.vgs",[Cust_ID]{99999},60,0,0,"c:\program Files\VoiceGuide\data\no_ans.vbs" "$RV[Cust_ID]" "$RV[OutDial_Result]" "$RV_CALLEDNUMBER" "$RV_LINEID" ,none] 125058.21 0 dial callque update id=250 next call time 0406131252 125058.21 0 dial callque DB update returned 125058.23 5 dial found entry: tel[19724756676] ann[] vgs["c:\program Files\VoiceGuide\data\test.vgs"] am["c:\program Files\VoiceGuide\data\ans_mach.vgs"] 125058.23 5 Dialing: 19724756676 125058.23 5 MakeCall => 65774 125058.23 5 TimeoutSet 60 EV_TIMEOUT_MAKECALL_NORESPONSE 125058.23 5 TapiCbTrigSet 65774 7002 125058.98 5 tapi Reply (LineEvReply) ok 65774 0 125058.98 5 TapiCbTrigClear 125058.99 5 linedevstate 2048 0 0 125058.99 5 callstate DIALTONE 65740 0 0 125058.99 5 callstate DIALING 65740 0 0 125058.00 5 callstate PROCEEDING 65740 0 0 125058.00 5 callinfo CALLEDID 125058.00 5 callinfo REASON 125059.01 5 Lev_CallerID [0000,] 125059.01 5 callinfo ORIGIN 125104.02 5 callstate CONNECTED 65740,1,0 125104.02 5 WorkingModeTAPI@Connected= 125104.02 5 WorkingModeScript@Connected= 125104.05 5 rv add [Cust_ID]{99999} 125104.05 5 rv add [OutDial_RetriesLeft]{0} 125104.05 5 rv add [$RV_STARTTIME]{6/13/2004 12:51:04 PM} 125104.05 5 rv add [$RV_DEVICEID]{5} 125104.05 5 rv add [$RV_CIDNAME]{} 125104.05 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 125104.05 5 rv add [$RV_CALLEDNUMBER]{19724756676} 125104.05 0 dial callque delete id=250 125104.07 5 AddRVns [OutDial_Result]{Contacted_Human} 125104.07 5 Live person answered, starting "c:\program Files\VoiceGuide\data\test.vgs" 125104.07 2 tr NewVgsVgm_Goto "c:\program Files\VoiceGuide\data\test.vgs",,,,,0 125104.07 5 rv add [scriptEnd_Time]{6/13/2004 12:51:04 PM} 125104.07 5 rv add [scriptEnd_Goto_Script]{"c:\program Files\VoiceGuide\data\test.vgs"} 125104.09 5 rv add [scriptEnd_Goto_Module]{} 125104.09 5 rv add [scriptStart_Time]{6/13/2004 12:51:04 PM} 125104.09 5 eng SetVgsVgm: file not found ["c:\program Files\VoiceGuide\data\test.vgs"]["c:\program Files\VoiceGuide\data\test.vgs"] 125104.09 5 Connected_OutgoingCall NewVgsVgm_Goto=>Error: NewVgsVgm_Goto_Setup failed 125104.09 0 dial callque delete id=250 125104.09 5 AddRVns [OutDial_Result]{Uncontactable_Error} 125104.11 5 RVreplace start: ["c:\program Files\VoiceGuide\data\no_ans.vbs" "$RV[Cust_ID]" "$RV[OutDial_Result]" "$RV_CALLEDNUMBER" "$RV_LINEID" ] 125104.11 5 RVns [Cust_ID]{99999}[OutDial_RetriesLeft]{0}[OutDial_Result]{Contacted_Human}[script nd_Time]{6/13/2004 12:51:04 PM}[scriptEnd_Goto_Script]{"c:\program Files\VoiceGuide\data\test.vgs"}[scriptEnd_Goto_Module]{}[scriptStart_Time]{6/13/2004 12:51:04 PM}[OutDial_Result]{Uncontactable_Error} 125104.11 5 RVreplace end: ["c:\program Files\VoiceGuide\data\no_ans.vbs" "99999" "Uncontactable_Error" "19724756676" "5" ] 125104.16 5 dial no escalation info 125104.16 5 TimeoutSet 1 EV_TIMEOUT_HANGUP 125105.05 5 Timer fired EV_TIMEOUT_HANGUP 125105.05 5 ScriptEventCode 9001 iLineState=5200 125105.05 5 LsWaitAfterDialingOut EV_TIMEOUT_HANGUP 125105.07 5 rv add [Hangup Time]{6/13/2004 12:51:05 PM} 125105.07 5 Hanging up call... [LsWaitAfterDialingOut] 125105.07 5 RecSoundStop ok 125105.07 5 PlaySoundStop err=0 125105.07 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 125105.07 5 Waiting for a call... 125105.09 5 fnHangupCall end 125105.13 5 linedevstate 2048 0 0 125105.14 5 callstate IDLE 65740 0 0 125105.14 5 WorkingMode@Idle= 125105.14 5 TimeoutClear 125105.14 5 LineState(iLineId).iVgsIdx = 0 125105.14 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE 125105.14 5 tapi Reply (LineEvReply) ok 65723 0 125106.09 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE 125106.09 5 ScriptEventCode 9008 iLineState=900 125106.09 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 125106.10 5 ReinitTelephony due to IDLE 125106.10 5 tapic lineDeallocateCall(MainCall:65740) 0 125106.28 5 lineOpen(5)=> 125106.28 5 Waiting for a call... 125106.28 5 LineHandle=65706 125106.28 5 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 125109.29 5 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 125109.29 5 ScriptEventCode 9013 iLineState=900 test.vgs Share this post Link to post
SupportTeam Report post Posted 06/13/2004 10:43 PM then something happens and it goes to Uncontactable_Error. Trace shows that VoiceGuide cannot find the file "c:\program Files\VoiceGuide\data\test.vgs". Does this file exist on your system? 125104.09 5 eng SetVgsVgm: file not found ["c:\program Files\VoiceGuide\data\test.vgs"]["c:\program Files\VoiceGuide\data\test.vgs"] Share this post Link to post
Guest Harry Report post Posted 06/14/2004 07:24 PM After further testing, this is what I discovered. Because I was using c:\Program Files as part of the path, I had to put quotes around the path in my XML. But then it complains that it can't find >"c:\program files\VoiceGuide\data\pgm.vgs"<. In other words it is including the quotes as part of the path name. I created another directory not under Program Files and put my scripts there and removed the quotes. It is working better, but this is a work around. Is there a better solution? Share this post Link to post
SupportTeam Report post Posted 06/15/2004 04:00 AM Because I was using c:\Program Files as part of the path, I had to put quotes around the path in my XML. Why? What error happened if you did not have any quotes? Have you tried 'single quotes' instead of "double quotes"? Share this post Link to post
Guest Guest Report post Posted 06/16/2004 02:09 AM Why? What error happened if you did not have any quotes? >>> With out quotes is said something like "Cannot find c:\program" Have you tried 'single quotes' instead of "double quotes"? >>>I have not tried single quotes. I was running 5.2.2000. I have since downloaded 5.2.2003, but I am still using my alternative directory. Share this post Link to post
