cramermark Report post Posted 06/15/2004 09:03 PM I have just installed a Dialogic 4DPCI Card and have it running on a P4, 2.6 Ghz, 512 Mb server. It seems to be running smoothly, and I am testing its ability to blind transfer. I have four lines that come in from the telephone company and the are all designed to blind transfer. I have manualy tested them to make sure that they work. 1. Call comes in to a line. 2. Hook/flash ==> new dialtone 3. Dial another number 4. Hook/flash calls are joined 5. Hang-up the phone I cannot get the call transfer to work using the transfer module. Here is my log-file. 144600.13 0 sys cleanup Start 144600.13 0 sys cleanup End 144613.19 7 linedevstate 2048 0 0 144613.19 7 callstate OFFERING 65846 0 4 144613.20 7 Answer the call at 6/15/2004 2:46:13 PM 144613.22 7 lineAnswer(65846) => 66119 144613.23 7 Lev_CallerID [3033937069,CRAMER MARK] 144613.25 7 Lev_CallerID [3033937069,CRAMER MARK] 144613.25 7 callinfo CALLEDID 144613.27 7 callinfo ORIGIN 144613.27 7 ring 0 144613.78 7 callstate CONNECTED 65846,1,0 144613.78 7 WorkingModeTAPI@Connected= 144613.80 7 WorkingModeScript@Connected= 144613.81 7 Inband detection not enabled 144613.81 7 StartLoadedVgs at 6/15/2004 2:46:13 PM 144613.81 7 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\} 144613.83 7 rv add [$RV_STARTTIME]{6/15/2004 2:46:13 PM} 144613.83 7 rv add [$RV_DEVICEID]{7} 144613.83 7 rv add [$RV_CIDNAME]{CRAMER MARK} 144613.83 7 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 144613.84 7 rv add [$RV_CIDNUMBER]{3033937069} 144613.84 7 tapi Reply (LineEvReply) ok 66119 0 144613.84 7 callinfo MONITORMODES 144613.86 7 TimeoutClear 144613.86 7 [Play 2] Playing 144613.86 7 [Play 2] Playing (C:\Program Files\VoiceGuide\Scripts\Voicemail Server\RentalTour_Welcome_Text.wav) 144613.94 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail Server\RentalTour_Welcome_Text.wav] 144613.94 7 TimeoutClear 144613.95 7 RunModule PLAY end 144613.95 7 wa(24954,85459300) 144613.97 7 callinfo MONITORMODES 144617.45 7 dtmf 1 (65846,49,2) 144617.47 7 ScriptEventCode 49 iLineState=1100 144617.47 7 LsPlayMsg 1 144617.53 7 PlaySoundStop err=0 144617.55 7 rv add [Play 2]{1} 144617.58 7 TimeoutClear 144617.58 7 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER 144618.02 7 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 144618.02 7 ScriptEventCode 9012 iLineState=1900 144618.02 7 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 144618.02 7 TimeoutSet 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 144618.03 7 [Transfer Call 3] Blind Transfer to 3033785618 (TAPI) 144618.03 7 lineBlindTransfer(65846,3033785618,0) in LsXferStart => 65999 144620.56 7 callstate ONHOLDPENDTRANSFER 65846 0 0 144622.11 7 linedevstate 2048 0 0 144622.13 7 callstate IDLE 65846 0 0 144622.13 7 WorkingMode@Idle=BlindTransfer 144622.13 7 TimeoutClear 144622.14 7 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE 144622.14 7 tapi Reply (LineEvReply) ok 65999 0 144623.17 7 Timer fired EV_TIMEOUT_TIMETOREINITLINE 144623.17 7 ScriptEventCode 9008 iLineState=1900 144623.17 7 LsXferStart EV_TIMEOUT_TIMETOREINITLINE 144623.17 7 ReinitTelephony due to IDLE 144623.19 7 tapic lineDeallocateCall(MainCall:65846) 0 144623.45 7 lineOpen(7)=> 144623.45 7 Waiting for a call... 144623.47 7 LineHandle=65658 144623.47 7 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 144626.75 7 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 144626.75 7 ScriptEventCode 9013 iLineState=1900 Thanks! Mark Share this post Link to post
SupportTeam Report post Posted 06/16/2004 12:06 AM I cannot get the call transfer to work using the transfer module What does the caller hear on the line when you attempt the transfer? Please read: http://www.voiceguide.com/vghelp/html/Dial...llTransfers.htm Share this post Link to post
