Rv Not Being Sent To Vbs
Here is my XML followed by the event log.
In the log you will notice the following lines:
153214.76 5 RVreplace start: [C:\VG_Script\no_ans.vbs "$RV[investCode]" "$RV[OutDial_Result]" "$RV_CALLEDNUMBER" "$RV_LINEID" "$RV[Comments] " ]
153214.76 5 RVns [Agent](2166)[investCode](57286)[Comments]( ) [Phone2](8179242462)[OutDial_RetriesLeft]{0}[DNIS]{19724756676}[OutDial_Result]{
ncontactable_Busy}
153214.77 5 RVreplace end: [C:\VG_Script\no_ans.vbs "0" "Uncontactable_Busy" "19724756676" "5" "0 " ]
My question is why is "$RV[investCode]" being passed as "0" to the vbs when it is showing a value on the RVns?
<OutDialEntry>
<PhoneNumber>19724756676</PhoneNumber>
<CallTime>2/24/2004</CallTime>
<DayTimeStart>10</DayTimeStart>
<DaysCallAllowed>MoTuWeThFrSa</DaysCallAllowed>
<AnnounceMessage></AnnounceMessage>
<OnAnswer>c:\VB_Script\answer.vgs</OnAnswer>
<OnAnswerMachine>c:\VB_Script\ans_mach.vbs</OnAnswerMachine>
<AnswerTimeout>c:\VB_Script\no_ans.vgs</AnswerTimeout>
<CallRetries>0</CallRetries>
<RetryDelay>0</RetryDelay>
<RV>[Agent](2166)[investCode](57286)[Comments]( ) [Phone2](8179242462)</RV>
<OnNotConnected>C:\VG_Script\no_ans.vbs "$RV[investCode]" "$RV[OutDial_Result]"
"$RV_CALLEDNUMBER" "$RV_LINEID" "$RV[Comments] " </OnNotConnected>
</OutDialEntry>
153206.66 0 Loading from C:\Program Files\VoiceGuide\data\OutDial_New.xml
153206.68 0 dial callque insert tel:19724756676 scr:c:\VB_Script\answer.vgs time:402240000 esc:none
153206.73 0 Loaded 1 entries.
153207.77 5 dial [10,19724756676,402240000,10,2359,MoTuWeThFrSa,,,,0,,c:\VB_Script\answer.vgs,c:\VB_Script\ans_mach.vbs,[Agent](2166)[investCode](57286)[Comments]( ) [Phone2](8179242462),60,0,0,C:\VG_Script\no_ans.vbs "$RV[investCode]" "$RV[OutDial_Result]" "$RV_CALLEDNUMBER" "$RV_LINEID" "$RV[Comments] " ,none]
153207.77 0 dial callque update id=10 next call time 0406171534
153207.77 0 dial callque DB update returned
153207.78 5 dial found entry: tel[19724756676] ann[] vgs[c:\VB_Script\answer.vgs] am[c:\VB_Script\ans_mach.vbs]
153207.78 5 Dialing: 19724756676
153207.78 5 MakeCall => 66376
153207.78 5 TimeoutSet 60 EV_TIMEOUT_MAKECALL_NORESPONSE
153207.78 5 TapiCbTrigSet 66376 7002
153208.54 5 tapi Reply (LineEvReply) ok 66376 0
153208.54 5 TapiCbTrigClear
153208.54 5 linedevstate 2048 0 0
153208.55 5 callstate DIALTONE 66120 0 0
153208.55 5 callstate DIALING 66120 0 0
153208.55 5 callstate PROCEEDING 66120 0 0
153208.56 5 callinfo CALLEDID
153208.56 5 callinfo REASON
153208.59 5 Lev_CallerID [0000,,19724756676]
153208.59 5 rv add [DNIS]{19724756676}
153208.59 5 callinfo ORIGIN
153214.73 5 callstate BUSY 66120 4 0
153214.73 0 dial callque delete id=10
153214.76 5 AddRVns [OutDial_Result]{Uncontactable_Busy}
153214.76 5 TimeoutClear
ncontactable_Busy}
153214.77 5 eng run vbscript [C:\VG_Script\no_ans.vbs "0" "Uncontactable_Busy" "19724756676" "5" "0 "]
153214.84 5 dial no escalation info
153214.87 5 rv add [Hangup Time]{6/17/2004 3:32:14 PM}
153214.87 5 Hanging up call... [busy]
153214.87 5 RecSoundStop ok
153214.89 5 PlaySoundStop err=0
153214.89 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
153214.91 5 Waiting for a call...
153214.91 5 fnHangupCall end
153214.96 5 linedevstate 2048 0 0
153214.96 5 callstate IDLE 66120 0 0
153214.96 5 WorkingMode@Idle=
153214.96 5 TimeoutClear
153214.98 5 LineState(iLineId).iVgsIdx = 0
153214.98 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
153214.98 5 tapi Reply (LineEvReply) ok 66069 0
153215.93 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
153215.93 5 ScriptEventCode 9008 iLineState=900
153215.97 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
153215.98 5 ReinitTelephony due to IDLE
153215.99 5 tapic lineDeallocateCall(MainCall:66120) 0
153216.17 5 lineOpen(5)=>
153216.17 5 Waiting for a call...
153216.18 5 LineHandle=66137
153216.18 5 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
153219.18 5 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
153219.18 5 ScriptEventCode 9013 iLineState=900
RVs in your XML file are specified incorrect. You should be using curly brackets instead of the parentheses. ie. This line:
should be:
<RV>[Agent]{2166}[investCode]{57286}[Comments]{}[Phone2]{8179242462}</RV>
