What Is The Data Fromat Of Result Variables
I am trying to get a date out of a VBS program and write it to a Access database.
in a long integer field then the result is 0.
in a text field the result is 1.66333998669328E-04
in a date field the result is 12/30/1899 (short date format)
my vbs program is below
Dim vardate
Dim vartime
Dim varhour
Dim varmin
Dim int_min
Dim int_year
Dim int_month
Dim int_day
Dim int_hour
Dim Date1
int_hour = $RV_Hour
int_day = $RV_Date
int_month = $RV_Month
int_year = $RV_Year
Select Case $RV_Minute ' the case statement below converts the minutes to the 15 minute interval minutes
Case 0,1,2,3,4,5,6,7
varmin = "0"
int_min = 0
Case 8,9,10,11,12,13,14,15,16,17,18,19,20,21,22
varmin = "15"
int_min = 15
Case 23,24,25,26,27,28,29,30,31,32,33,34,35,36,37
varmin = "30"
int_min = 30
Case 38,39,40,41,42,43,44,45,46,47,48,49,50,51,52
varmin = "45"
int_min = 45
Case 53,54,55,56,57,58,59
varmin = "0"
int_min = 0
int_hour = $RV_hour + 1
End Select
If int_hour = 24 Then
int_hour = 0
int_day = int_day + 1
End If
Date1 = DateSerial(int_year,int_month,int_day) 'DateSerial is a built in VBS function - it adjusts to the new date if int_day has changed
varhour = cstr(int_hour)
varmin = cstr(int_min) ' will need to update the database with int_min, which is the adjusted minute amount; int_hour and Date1
wscript.echo varhour
wscript.echo varmin
vg.RvSet $RV_LINEID, "NewHour", varhour
set vg = Nothing
vg.RvSet $RV_LINEID, "NewDate", Date1
set vg = Nothing
vg.RvSet $RV_LINEID, "NewMin", varmin
set vg = Nothing
The log is below ( i only included what I think is important)
124601.49 7 [RunVb] Running VB Script...
124601.49 7 RVreplace start (strlen>500)
124601.51 7 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{U:\My Documents\VoiceGuide\}[$RV_STARTTIME]{6/18/2004 12:45:37 PM}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{9018697787}[CallerID_Input]{9018697787}[CallerID]{9018697787}
CallerIDWasSentRequestSSN]{111111111}[CallerIDWasSentRequestSSN_PathTaken]{succe
s}[CheckForValidSSN_RowCount]{1}[CheckForValidSSN_1_1]{27}[CheckForValidSSN_2_1]
JORGCM }[CheckForValidSSN_3_1]{111111111}[CheckForValidSSN_4_1]{xxxxxxxxx }[CheckForValidSSN_5_1]{xxxxxx x. }[CheckForValidSSN_6_1]{2/11/2002}[CheckForValidSSN_7_1]{HELP DESK/PROGRAMMER }[CheckForValidSSN_8_1]{FT }[CheckForValidSSN_9_1]{}[CheckForValidSSN_10_1]{F}[CheckForValidSSN_11_1]{C}[Ch
ckForValidSSN_12_1]{9016858923}[CheckForValidSSN_13_1]{xxx xxxxxxxxx- HUSBAND }[CheckForValidSSN_14_1]{6/24/1961}[CheckForValidSSN_15_1]{S}[CheckForValidSSN_16_1]{S}[MakeSureNotTerminated_
nput]{=""}[MakeSureNotTerminated]{=""}[RecordName]{U:\My Documents\VoiceGuide\RecordedVoicesAtClockInOut\0618124549_7_9018697787.wav}[RecordName_RecLen100ms]{31}[RecordName_EndRecC
use]{timeout}[QueryForStatusIn_Out_RowCount]{1}[QueryForStatusIn_Out_1_1]{OUT}[Q
eryForStatusIn_Out_2_1]{118}[Eval_IfComingToWork_Input]{"OUT" ="OUT"}[Eval_IfComingToWork]{True}[ifYouAreComingToWork]{1}[setClockinStatusToIN_
owCount]{1}
124601.51 7 eng copy of script ran: vbs_7_1.vbs
124601.54 7 Run Script waiting... (shellid=2372, process=1556)
124601.54 7 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
124602.55 7 Timer fired EV_TIMEOUT_CHECKONSTATE
124602.55 7 ScriptEventCode 9007 iLineState=1501
124602.55 7 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
124602.57 7 task still running (shellid=2372, process=1556)
124602.57 7 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
124603.68 7 Timer fired EV_TIMEOUT_CHECKONSTATE
124603.68 7 ScriptEventCode 9007 iLineState=1501
124603.68 7 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
124603.70 7 task still running (shellid=2372, process=1556)
124603.70 7 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
124604.27 7 cl RvSet NewHour, 12
124604.27 7 rv add [NewHour]{12}
124604.29 7 cl RvSet NewDate, 6/18/2004
124604.29 7 rv add [NewDate]{6/18/2004}
124604.29 7 cl RvSet NewMin, 45
124604.29 7 rv add [NewMin]{45}
124604.80 7 Timer fired EV_TIMEOUT_CHECKONSTATE
124604.80 7 ScriptEventCode 9007 iLineState=1501
124604.80 7 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
124604.80 7 task completed (shellid=2372, process=1556)
124604.82 7 No information returned from program to VG (no VGRUNRESULT_7.TXT or SHLRESLT.TXT)
124604.82 7 TimeoutClear
124604.82 7 [updateVoiceguideLogClockingIn] DB Query
124604.84 7 db Jet mode used (To use ODBC mode specify ODBC Connect string)
124605.10 7 RVreplace start (strlen>500)
124605.10 7 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{U:\My Documents\VoiceGuide\}[$RV_STARTTIME]{6/18/2004 12:45:37 PM}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{9018697787}[CallerID_Input]{9018697787}[CallerID]{9018697787}
Jxxxxxxx }[CheckForValidSSN_3_1]{111111111}[CheckForValidSSN_4_1]{xxxxxxxx }[CheckForValidSSN_5_1]{aaaaaaaaa a. }[CheckForValidSSN_6_1]{2/11/2002}[CheckForValidSSN_7_1]{HELP DESK/PROGRAMMER }[CheckForValidSSN_8_1]{FT }[CheckForValidSSN_9_1]{}[CheckForValidSSN_10_1]{F}[CheckForValidSSN_11_1]{C}[Ch
ckForValidSSN_12_1]{1234567899}[CheckForValidSSN_13_1]{xxx xxxxxxxx - HUSBAND }[CheckForValidSSN_14_1]{6/24/1961}[CheckForValidSSN_15_1]{S}[CheckForValidSSN_16_1]{S}[MakeSureNotTerminated_
owCount]{1}[NewHour]{12}[NewDate]{6/18/2004}[NewMin]{45}
124605.12 7 db About to execute a Modify type operation [insert into voiceguide_log (ssn,calldatetime,calldate,callstat,cid,calltime,seq,calldate_new,calltime_hour,
alltime_min,calltime_time,channel_no,ssnseq,wavefilename,New_date) values ('111111111','6/18/2004 12:45:37 PM','6'+"/"+'18'+"/"+'2004','IN','9018697787','12'+":"+'46',118,6/18/2004,12,45,6/18/2004,7,'111111111'+cstr(118),'U:\My Documents\VoiceGuide\RecordedVoicesAtClockInOut\0618124549_7_9018697787.wav',6/18/2004)]
124606.46 7 db Modify operation returned OK
124606.46 7 rv add [updateVoiceguideLogClockingIn_RowCount]{1}
124607.76 7 TimeoutClear
note the date is listed correctly in the values part of the insert statement
calltime is the long integer field
calldate_new is the text field
and New_date is the short date field
What is your actual problem/question?
Is it that you cannot get your SQL statement correct to insert a date/time field into the database?
I'd suggest reading your database manual to find out how to specify the date/time in the SQL statement so that it is correctly read in by the database.
For MS Access a date/time field specified like this will work:
strDateTime = "#" & FormatDateTime(Now, vbShortDate) & " " & FormatDateTime(Now, vbLongTime) & "#"
