Guest Oded Report post Posted 06/21/2004 06:42 PM Hello i have Conexant V.92 modem and PBX KX-T30820 of Panasonic. i tried using all the transfer options (even 3way) and the thing is the modem wont transfer the call, it will hang up and dial the extansion... what can i do??? thank you all! Share this post Link to post
Guest Oded Report post Posted 06/21/2004 06:48 PM let me rephrase the problem the modem transfers me, on the line i hear music of transfer, the extension gets the call, and says press 1 to accept. before i press i hear on the caller side, no music, and after pressing 1 it will hang up the extension call! and wont connect the calls Share this post Link to post
SupportTeam Report post Posted 06/21/2004 11:36 PM How do you usually do call transfers on this system? Please describe step by step. Share this post Link to post
Guest Oded Report post Posted 06/22/2004 04:19 AM what do you mean? in regular phone? while talking, i press flash , then the extension number, and then hang up Share this post Link to post
SupportTeam Report post Posted 06/22/2004 05:10 AM Do you have to wait for the destination extension to answer the call before you hang up or do you just hang up while the destination extension is ringing? If you do not need to wait for destination extension to answer then you should just use the 'blind transfer' option. What happens when you use that option? Share this post Link to post
