Dialogic
I recently purchased a Dailogic SPCI ss7 board.
I did not receive any drivers or software. I can not install it under Win2003 Server
...you should speak with the people who sold you the card.. or with your local Intel/Dialogic reseller.
i m also using SPCI ss7 intel board. i have installed intel netstructure development package and also SR5.1.1 and Feature pack . but Board is not configured propely.. how can i properly install and configure the SS7 board..
thanx in advance
Best Regards
  SupportTeam said:
You should speak with the Dialogic card supplier...
I have a Dialogic SPCI4 SS7 board and Dialogic DMV 1200 board. They are connected by CT bus. I configured them and they are working fine. I need to use VG. Is VG compatible with the boards that I have? Do VG needs a certain configuration to be able to work with them?
Thanks for cooperation,
Ayman Moustafa.
Yes, VoiceGuide v7 can work on SS7.
Configuring SS7 is not as straightforward as setting up ISDN/VoIP/etc lines so at this stage all SS7 system installs are carried out by our technical staff.
To perform the installation we would require access to the system using a remote access service/software. eg: PCAnywhere or VNC or logmein.com or RemoteDesktop etc.
Please email your contact details to support@voiceguide.com to obtain further information.
