Voicemail Message Not E-mailed
I have Outlook Express Running on my desktop on Windows XP Home, and I have VG 5.2.2 with a D4PCI Card.
If I leave a voicemail in a box that has a forwarding e-mail, and set up the email section of voicemail to use Outlook Express the email never gets sent.
I have attached the log file.
Thanks for the help.
--Mark
E_mail.txt
You cannot use Outlook Express - the Help file refers to the 'full' version of Outlook.
It's easiest to just specify the SMTP server anyway - have you tried doing that? (just copy the SMTP settings from Outlook Express).
I have tried the SMTP route as well, but I am still not getting the e-mail. The settings are exactly as they are in Outlook.
I have attached the log for the SMTP approach.
Thanks--
Mark
SMTP.txt
There should be a MMDDes.txt trace file in VoiceGuide's \log\ subdirectory - please post that file - that is the log of SMTP server interactions.
When I navigate to c:/Program Files/Voiceguide/Log there is no log MMDDes.txt?
I searched the VoiceGuide file for MMDDes.txt and could not find it either?
Thank you--
Mark
MMDD stands for "Month" and "Day" eg: July 2 would be "0702"
You will need to select a 'save to file' option in VG in order for these log files to be saved. (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - then tick the 'save to file' box).
Trace shows that either:
"The SMTP Host did not respond to the request"
or
"The attempt to connect timed out"
or
"Connection is forcefully rejected"
so for some reason the SMTP server does not like to accept email send attempts from VoiceGuide.
You may want to ask the SMTP server administrator - the SMTP server ought to have a record of attempted sends and the administrator may be able to look at these logs and tell you why the SMTP server is not accepting connections from VG.
Just for reference, here is what a trace of a successful send looks like (for demonstration first SMTP server name is faulty and VG then uses the backup SMTP server to send out the email):
144327.78  0 eng   prog start 14:43:27 02 Jul
144327.89  0 que   found 1/1
144327.89  0 que   current: ID=2
144327.89  0 que   update ID=2to SendTime=0407021444  SendRetriesLeft=2
144327.91  0 smtp  Status Connecting to SMTP Server (mail5.bigpond.com)...
144327.98  0 smtp  SendFailed Authoritative answer: Host not found
144327.98  0 smtp  Status Closing Connection...
144328.00  0 eng   send attempt 1 result = [fail]
144328.00  0 smtp  Status Connecting to SMTP Server (mail.bigpond.com)...
144328.06  0 smtp  Status Initializing Communications...
144328.11  0 eng   smtp send start To:destsend@katalina.com.au, Cc:cc@katalina.com.au, Bcc:
144328.11  0 smtp  Status Sending Sender Information...
144328.11  0 smtp  Progress 11%
144328.59  0 smtp  Status Sending Recipient Information...
144328.59  0 smtp  Progress 21%
144328.63  0 smtp  Progress 29%
144328.66  0 smtp  Status Sending Message...
144328.66  0 smtp  Progress 30%
144328.70  0 smtp  Progress 100%
144328.84  0 smtp  Progress 100%
144328.84  0 smtp  Status Transmission Complete...
144328.84  0 smtp  SendSuccesful
144328.84  0 que   delete ID=2
144328.84  0 eng   smtp send end
144328.84  0 smtp  Status Closing Connection...
144328.88  0 eng   send attempt 2 result = success
144328.98  0 eng   prog end   14:43:28 02 Jul
