Guest JHON77 Report post Posted 06/29/2004 04:41 PM Hello, I read the system requirements for using voiceguide. Are thos values (pentium 4, 128 RAM) the same for every type of license no matter how many lines it is working with?. In other words, Will the same (pentium 4 128 RAM) PC work well with an one line and a 24 line voiceguide program?. If not, What are the suggested amount of RAM and speed for the PC I will be using, depending on the number of lines I will be working with?. I have special interest in 4, 8, 16 and 24 lines. Thank you very much. Share this post Link to post
SupportTeam Report post Posted 06/30/2004 01:48 AM For a 24 line system we'd recommend using about a 1GHz P4 with about 512MB RAM. It all depends on how intensive your application is. If you work with large databases or run a lot of VB Scripts in your system then you will need a faster machine then if you are just running a simple auto-attendant type application. Share this post Link to post
