Guest Dave Young Report post Posted 06/30/2004 09:15 AM Hi, we are trying to set up a test of Voiceguide with a Netcomm Wave V.92 prior to purchasing a dialogic card. I am trying to transfer a call and the PBX seems to get the hookflash as it puts the call on hold but it does not seem to dial the extn no? Any thoughts (our PBX is a Panasonic KX-TD816) Cheers DY Share this post Link to post
SupportTeam Report post Posted 06/30/2004 10:43 AM Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong. (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call.) Share this post Link to post
Guest David Young Report post Posted 07/01/2004 08:38 AM Log file while attempting to transfer 183001.35 1 callstate OFFERING 66134 0 4 183001.35 1 Answer the call at 7/1/2004 6:30:01 PM 183001.38 1 lineAnswer(66134) => 66117 183001.38 1 ring 1 183001.38 1 callstate ACCEPTED 66134 0 0 183004.59 1 tapi Reply (LineEvReply) ok 66117 0 183004.59 1 callstate CONNECTED 66134,0,0 183004.59 1 WorkingModeTAPI@Connected= 183004.59 1 WorkingModeScript@Connected= 183004.59 1 Inband detection not enabled 183004.59 1 StartLoadedVgs at 7/1/2004 6:30:04 PM 183004.59 1 AddRVns [scriptsPath]{C:\Documents and Settings\davidy\Desktop\} 183004.60 1 rv add [$RV_STARTTIME]{7/1/2004 6:30:04 PM} 183004.60 1 rv add [$RV_DEVICEID]{1} 183004.60 1 rv add [$RV_CIDNAME]{} 183004.60 1 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 183004.60 1 rv add [$RV_CIDNUMBER]{} 183004.62 1 TimeoutClear 183004.62 1 [Welcome] Number Input 183004.62 1 [Welcome] Playing (C:\Program Files\VoiceGuide\system\voice\RecMsgMenu.wav) 183004.76 1 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\RecMsgMenu.wav] 183004.76 1 TimeoutClear 183004.76 1 wa(9697,50680200) 183007.82 1 dtmf 1 (66134,49,2) 183007.82 1 ScriptEventCode 49 iLineState=1300 183007.82 1 LsGetNbrsPlayWelcMsg 1 183007.83 1 PlaySoundStop err=0 183007.83 1 [Welcome] Number Input 1 183007.84 1 rv add [Welcome]{1} 183007.84 1 TimeoutClear 183007.84 1 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER 183008.17 1 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 183008.17 1 ScriptEventCode 9012 iLineState=1900 183008.17 1 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 183008.18 1 TimeoutSet 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 183008.18 1 [sales AJ] Blind Transfer to ,,,201,, (Generate) 183008.18 1 tapic lineGenerateDigits(66134,!,0) => 0 183008.31 1 generate LINEGENERATETERM_DONE 183008.31 1 TimeoutSet 1 EV_TAPI_GENERATE 183009.29 1 Timer fired EV_TAPI_GENERATE 183009.29 1 ScriptEventCode 9602 iLineState=1900 183009.29 1 LsXferStart EV_TAPI_GENERATE 183009.30 1 TimeoutSet 1 EV_HOOKFLASHFINISHED 183010.30 1 Timer fired EV_HOOKFLASHFINISHED 183010.30 1 ScriptEventCode 9200 iLineState=1905 183010.30 1 LsXferPlayVts EV_HOOKFLASHFINISHED 183010.31 1 tapic lineGenerateDigits(66134,,,,201,,,0) => 0 183010.34 1 generate LINEGENERATETERM_CANCEL 183010.34 1 TimeoutSet 1 EV_TAPI_GENERATE 183011.31 1 Timer fired EV_TAPI_GENERATE 183011.31 1 ScriptEventCode 9602 iLineState=1905 183011.33 1 LsXferPlayVts EV_TAPI_GENERATE 183011.33 1 TimeoutSet 3 EV_TIMEOUT_HANGUP 183014.34 1 Timer fired EV_TIMEOUT_HANGUP 183014.34 1 ScriptEventCode 9001 iLineState=1905 183014.34 1 LsXferPlayVts EV_TIMEOUT_HANGUP 183014.35 1 rv add [Hangup Time]{7/1/2004 6:30:14 PM} 183014.35 1 Hanging up call... 183014.35 1 RecSoundStop ok 183014.36 1 PlaySoundStop err=0 183014.36 1 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 183014.36 1 fnHangupCall end 183015.56 1 callstate DISCONNECTED 66134,1,0 183015.56 1 ScriptEventCode 9250 iLineState=900 183015.56 1 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT 183015.56 1 rv add [Hangup Time]{7/1/2004 6:30:15 PM} 183015.57 1 Hanging up call... 183015.57 1 RecSoundStop ok 183015.57 1 PlaySoundStop err=0 183015.58 1 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 183015.58 1 fnHangupCall end 183015.58 1 callstate IDLE 66134 0 0 183015.59 1 WorkingMode@Idle= 183015.59 1 TimeoutClear 183015.71 1 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE 183015.71 1 tapi Reply (LineEvReply) ok 66066 0 183015.71 1 tapi Reply (LineEvReply) ok 66049 0 183016.61 1 Timer fired EV_TIMEOUT_TIMETOREINITLINE 183016.61 1 ScriptEventCode 9008 iLineState=900 183016.61 1 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 183016.61 1 ReinitTelephony due to IDLE 183016.63 1 tapic lineDeallocateCall(MainCall:66134) 0 183016.70 1 lineOpen(1)=> 183016.70 1 Waiting for a call... 183016.70 1 LineHandle=66032 183016.71 1 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 183019.73 1 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 183019.73 1 ScriptEventCode 9013 iLineState=900 Share this post Link to post
SupportTeam Report post Posted 07/01/2004 10:04 AM Looks like this modem does not like commas in it's string of digits to be played. As a workaround I'd suggest using two Play modules, with the first module playing (with 0 replays) just: ! and then a timeout path leading from it to the next module which plays (with 0 replays) just: 201 The timeout path would be used to have a pause in between the hookflash and the extension, so there would be no need for the commas. Share this post Link to post
Guest David Young Report post Posted 07/01/2004 11:30 PM Thanks this works...great support forum! Share this post Link to post
