D/41e Isa Card
Hi. I've just purchased a Dialalogic D/41E ISA card, but I have been unable to configure it because of a 'Error configuring the TDM Bus' thats related to 'Failed to detect board'. The Intel SR5.1.1 configuring software can see the card because when I change the position rotary switch on the card the software sees the card's new position. So I would assume the card is working somewhat. Am I doing something wrong or have I bought a dud.
Cheers
Sounds like the card is faulty. Usually you just insert the card in PC and the drivers just find the card without any such messages.
I'm led to believe this card is OK. I think the problem is I may not have the correct drivers installed (can not find any on the net) or I may have use an earlier SR5 version software. Thoughts ????
Cheers
