Evaluate Information From The Web
I am trying to varify information I retreive from the web is correct. If the information comes back to me correctly the strlen is about 10-20 charecters. If there are no results returned or an error, I get 0 or 500 charecters or more. what I am trying to do is evaluate the information like strlen($RV{whatever}) <=40 or Len($RV[sLNE]) <= 40 or maybe 0 = Len($RV[sLNE]) >= 40
Will something like these work with a string
Neither seem to do the trick, I am trying to evaluate the entire string charecters not a number. any tips or tricks?
So if length is between 10 and 20 characters then we should take the Success path and take the Fail path otherwise. Use this expression in the Evaluate Expression module:
(len("$RV[xyz]") >= 10) and (len("$RV[xyz]") <= 20)
where $RV[xyz] shoudl be replaced by your result varaible.
THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU, You guys are the best!
